Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by msg on May 4, 2008, 2:17 am
Please log in for more thread options Starlan 1 Mbps? Michael | ||||
Posted by ps56k on May 4, 2008, 2:24 am
Please log in for more thread options > Jeff Liebermann wrote:
> > <snip> >> 4. In the miscellaneous category,... ethernet over 25 pair
>> telco bundles >
> Starlan 1 Mbps? > > Michael wow - StarLan - That really takes me back... We creating the video training and marketing materials... | ||||
Posted by Jeff Liebermann on May 4, 2008, 4:02 am
>> telco bundles >Starlan 1 Mbps?
>Michael Nope. 10Mbits/sec half-duplex ethernet over 25 pair telco bundles. Works fine up to about 100ft. It might work farther, but I haven't tried it. Gaaak. Starlan brings back not very fond memories of doing battle with 3B2-400 clunkers using Ma Bell 258A wiring on CAT3 shared with Pre-Merlin phone systems. I had no idea what I was doing, so it's little wonder that I could never make it all work quite right. Sorry, no LatticeNet. Some Token Ring (4Mbit/sec), Moses Networks Promise LAN, DECNet, Novell Netware, 3com something pure ISO stack, Microsoft LAN Manager, Lantastic, and probably a few more that I'm successfully forgotten about. Add a bunch of TCP/IP implimentations for Windoze 3.x that never quite worked right, and a mess of non-802.11 schemes and protocols, that went nowhere. -- Jeff Liebermann jeffl@cruzio.com 150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 http://802.11junk.com Skype: JeffLiebermann AE6KS 831-336-2558 | ||||
Posted by ps56k on May 4, 2008, 12:42 pm
> with 3B2-400 clunkers using Ma Bell 258A wiring on CAT3 shared with > Pre-Merlin phone systems. I had no idea what I was doing, so it's > little wonder that I could never make it all work quite right. 3B2 - ahhhhhh - We also did the training video & product intro for the "Unix PC" - along with the IBM 3270 replacement..... can't recall the number, maybe 6500 ? Lastly - we did the AT&T PC product materials & launch - ahhhhhh - | ||||
Posted by Rich Seifert on May 4, 2008, 12:55 pm
I knew some of the developers there, and just *loved* the product name. In the end, it was more of a promise than a LAN, however. My all-time favorite communications product name was from a company (whose name I forget) up in Marin county who built a very simple device. "Back in the day", terminals connected to computers using modems, which had a "DCE flavor" (modem-to-host computer) and a "DTE flavor" (modem-to-terminal) for the wiring. If you wanted to connect a terminal directly to a computer, you could eliminate the modem, but needed to cross-connect the transmit/receive pairs in the cable. Today we all know this as a "null modem" cable, and it is fairly ubiquitous, but it hasn't always been so. This small company marketed a "null modem" device; a small box that had the transmit/receive cross-wiring, with connectors that would allow the use of ordinary, uncrossed-wiring modem cables to the DTE and DCE. Simple, but useful if you don't have a null modem cable. No technological genius here, but great marketing savvy. Instead of calling it a "cable crossover" or some such, they called the device a "QuasiModem"--the box had a picture of a bent-over Quasimodo carrying the device under his arm, with the slogan "We've got a *hunch* you'll like it!" Believe it or not, between the last two sentences I just went outside my office and shot a bobcat who was chasing my house cat, whose name happens to be "Cat 3"(he is my third cat). No, I am not planning to upgrade him to Cat 5. -- Rich Seifert Networks and Communications Consulting 21885 Bear Creek Way (408) 395-5700 Los Gatos, CA 95033 (408) 228-0803 FAX Send replies to: usenet at richseifert dot com | ||||
| Similar Threads | Posted |
| Re: Ethernet connection sensitive to cable length | May 3, 2008, 12:37 pm |
| telephone connection with cat5e | July 13, 2005, 10:40 am |
| Trouble with B2B fiber connection | August 3, 2005, 9:03 am |
| Network connection only stable @ 10mbit. | January 28, 2005, 2:09 pm |
| MDF cross connection block test clips | July 21, 2005, 7:39 pm |
| Cable length | July 18, 2006, 9:43 pm |
| Minimum 10Base100 Cable Length | July 16, 2004, 9:32 am |
| Program to Estimate Cat 5 Cable Length | October 1, 2004, 4:52 pm |
| Power + DSL signal in same 700ft cable length | October 12, 2006, 6:35 pm |
| OTDR: Launch Cable Length for Singlemode | April 10, 2008, 2:50 pm |
| Ethernet cable shield | November 23, 2004, 5:02 pm |
| Ethernet Cable Woes - On and Off every second | February 19, 2007, 8:20 pm |
| Firewire using on existing Ethernet cable | August 6, 2005, 7:36 am |
| Cable over ethernet for two Wireless access points | July 23, 2004, 6:57 pm |
| CAT-5 cable stuck in ethernet port - can't remove | April 26, 2006, 5:49 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> telco bundles
