LAN and Telecom Cabling Re Cable Managers - 1U vs 2U
Subject Author Date
Re Cable Managers - 1U vs 2U Lincoln J. King-Cliby 08-13-04
Posted by Lincoln J. King-Cliby on August 13, 2004, 10:28 am
[Appologies for this not being a 'standard' reply; as the original
message was flagged wiht X-No-Archive, its not possible to locate it
with Google Groups and give a proper response]
My gut feeling would be to use 2-unit cable management stuff for the
majority of the needs. It is far better to have excess capacity than
not enough capacity, IMHO, and it's nice to get the space now, because
if you decid you need it in the future after everything is wired...
Also, I'm not sure that I'd say that flat satin voice cable --
especially in bundles of 48 is 'much' smaller than UTP. It depends on
what flat satin and what UTP your using, but maybe a little over 1/2
the space requirement.
My $.02: If you have the rackspace to spare, use the 2U cable
management panels; if you don't have the rackspace to use the 2U cable
menagement panels, add another rack and use the 2U panels; if you
don't have the room for another rack, use the 1U panels
Lincoln
Chris Keath wrote:
> Can anyone offer any advice on when to use 2U high Cable Managers vs
> 1U ?
> I'm thinking along the following
> 1U Height Cable Manager
> 2U 48 Port Data Patch Panel
> 2 U Cable Manager
> 1U 48 Port Switch
> 2 U Cable Manager
> 2U 48 Port Voice Patch Panel
> 1U or 2U Cable Manager (vendor will be using regular 2 conductor RJ11
> cables )
> 2U IP Office (telephone system)
> 1U Cable Manager
> 2U IP Office
> 1U Cable Manager
> 2U IP Office
> 1U Cable Manager
> I can get away with the 1U on the Cable Manager between the voice
> patch panel because the cable is much smaller ? Yay or Nay ? Should I
> just stick with the 2U on that
Posted by Justin T. Clausen on August 13, 2004, 7:49 pm
I would second Linclon's approach. I try not to use 1U managers a
much as possible. At worst, I'll put a 1U at the top and bottom of a
stack of a 2U-48 port panels, with 2U inbetween each panel.
> Lincoln
> > 1U ?
> > 2 U Cable Manager
> > 1U 48 Port Switch
> > 2 U Cable Manager
> > cables )
> > 1U Cable Manager
> > 2U IP Office
> > 1U Cable Manager
> > 2U IP Office
> > 1U Cable Manager
Similar ThreadsPosted
Cable Managers - 1U vs 2U August 12, 2004, 11:01 pm
Re Cable Managers - 1U vs 2U August 13, 2004, 10:28 am
OTDR: Launch Cable; Receive Cable April 10, 2008, 2:46 pm
Can I use a CAT5 cable as a TV Coax cable? October 14, 2006, 2:13 pm
Which end is bad of cable July 7, 2005, 10:51 pm
What is the best way to strip Cat 5 cable November 27, 2004, 12:17 pm
Question about Cat 7 cable February 1, 2005, 2:03 pm
How long can a cable be February 21, 2005, 7:31 am
Cable labeler? April 22, 2005, 11:32 am
ISDN cable July 20, 2005, 11:29 am
Cable tester July 21, 2005, 12:07 am
Decent Cat 5/6 cable? July 21, 2005, 12:30 pm
cable picture November 29, 2005, 4:11 pm
Please identify this cable? July 1, 2006, 5:59 pm
