LAN and Telecom Cabling RJ45 splitter for Ethernet - possible ?
Subject Author Date
RJ45 splitter for Ethernet - possible ? P.Schuman 03-28-08
Posted by on March 28, 2008, 4:47 pm
gfretwell@aol.com wrote:
> Don't do this with POTS phones unless you can live with the errors
> when the phone rings.
Since 10Base-T and 100Base-TX were both designed to coexist with phone
lines in the same cable, that shouldn't be a problem.
-Larry Jones
Start tying the sheets together. We'll go out the window. -- Calvin
Posted by News Reader on March 28, 2008, 7:03 pm
Possible and advisable are two different things.
A telephone ringing signal is an 88v 20Hz A.C. signal superimposed on
48v nominal D.C. supervisory voltage.
Hardly low voltage, and not appropriate for sharing a Cat 5e cable run
with data.
Readers should observe gfretwell's caution.
Best Regards,
News Reader
> -Larry Jones
Posted by on March 28, 2008, 10:08 pm
Absolutely.
> with data.
The former is true, the latter is debatable. Cat5 cable is used for
phone wiring, so the voltage is not a problem for it (in fact, most Cat5
cable is rated for 300V). The IEEE 802.3 spec for twisted pair ethernet
requires devices to provide at least 1500V of isolation, so it's not a
problem for the attached devices, either. And the baseband signal is up
in the MHz range, so the receiver won't even see a 20Hz signal. Like I
said, twisted pair ethernet was specifically designed to coexist with
ordinary phone circuits in the same cable, although that's not
recommended for structured wiring systems.
-Larry Jones
No one can prove I did that!! -- Calvin
Posted by News Reader on March 29, 2008, 12:00 pm
The point is not whether the "cable" can withstand high voltage.
The point is that Ethernet is a low voltage, low current implementation.
The issue is induction, and induction results from current, not voltage.
If you think a high current, low frequency signal cannot impact the
receiver, you are incorrect.
If you were correct, we would not observe the minimum separation
distances from EMI sources that we do, when installing network cabling.
We keep data cabling away from AC wiring (i.e.: 60 Hz), and if we have
to cross paths with AC, we ensure that we are perpendicular to the AC
wiring, and never parallel to it, due to the effects of induction.
Best Regards,
News Reader
> Absolutely.
>> with data.
> -Larry Jones
Posted by Robert Redelmeier on March 29, 2008, 2:01 pm
> impact the receiver, you are incorrect.
Well, technically ULF is seen at the receiver, but it is
too slow and neutralized by balanced signalling to make
any difference in the detection process.
> separation distances from EMI sources that we do, when
There are many other reasons for separation. First and foremost
is the dreaded electrical inspector who will often insist upon
it (for electrical "safety") and her word is law. Second, some
AC loads get very HF noisy (arc welders, certain motors and X-ray
machines are frequently cited) and inject high freq noise onto AC.
This noise can be troublesome.
> if we have to cross paths with AC, we ensure that we are
> perpendicular to the AC wiring, and never parallel to it,
A clean AC draw (incandescent lighting) may produce some 60
Hz induction, but it is harmless and easily rejected by the
receiver. Similarly the telephone ring 88V, 20Hz, unless
you have an antique phone with contacts on the bell armature.
Even then the protocols are robust and will retransmit.
> Best Regards, News Reader
Please refrain from top-posting. The convention is
quote-and-respond which makes following threads and
side-comments easier.
-- Robert
Similar ThreadsPosted
RJ45 splitter for Ethernet - possible ? March 28, 2008, 11:56 am
Ethernet: which RJ45 pins? August 9, 2007, 9:49 am
best RJ45 crimper under $100? August 14, 2005, 3:27 pm
1 RJ45 to 4 BT converter? August 31, 2005, 3:18 pm
RJ45 connector question July 8, 2004, 2:55 pm
RJ45 to 110 Cross-Connects August 24, 2004, 1:13 am
DB25-to-RJ45 Adapters December 17, 2005, 8:04 pm
RJ45 connectors with a larger "gate"? September 22, 2004, 10:22 pm
RJ45 connectors with a larger "gate"? September 23, 2004, 9:59 pm
Corrosion in RJ11 / RJ45 Connectors April 14, 2005, 5:51 am
panel mounted RJ45 socket? August 9, 2005, 11:25 am
tool to ease RJ45 termination April 17, 2007, 11:13 am
Wiring on RJ45 wall socket July 8, 2007, 6:22 am
RJ45 Cat5e cables - male one one end, female (keystone) on other July 21, 2005, 3:48 pm
DIY Ethernet September 10, 2004, 8:57 pm
