LAN and Telecom Cabling RJ45 splitter for Ethernet - possible ?
Subject Author Date
RJ45 splitter for Ethernet - possible ? P.Schuman 03-28-08
Posted by News Reader on March 28, 2008, 12:51 pm
You are overlooking the key point.
The splitter is remapping pin placements.
Pins 1,2,3, and 6 on one of the female jacks are mapped to 1,2,3 and 6
on the male end, as you would expect.
The other female jack maps its pins 1,2,3, 6 to the other two wire pairs
(pins 4,5,7 and 8) on the male end.
Best Regards,
News Reader
P.Schuman wrote:
> News Reader wrote:
>> I've had splitters like this in my tool box for the past decade, but
>> have not actually implemented them.
> ok - that pretty much answers the rest of your points
>> Mine, are male on one side, and two female on the other.
>> Imagine that you plugged one into a wall jack at the location of a
>> workstation, and another in the closet where your switch resides.
>> This would support two Ethernet or FastEthernet devices at the
>> workstation location (e.g.: host, and network attached printer).
> really - how ?
>> Each device would utilize two of the four pairs within the 8-wire
>> (e.g.: Cat 5e) cable.
> really - how ?
> considering that each Ethernet device normally expects pins 1/2 and 3/6
> to be used ?
> So, you would have to fabricate a custom cable for each of these
> connections at each end
> and then plug that cable into your cable-sharing RJ45 splitters..
> 1/2 = 1/2
> 3/6 = 3/4
> 1/2 = 5/6
> 3/6 = 7/8
>> This is however, not an appropriate thing to do from a performance
>> standpoint, and should not be standard practice.
>> If you were utilizing GigEthernet, I believe all four pairs are used
>> to support a single device, and therefore splitting would not be an
>> option.
>> Best Regards,
>> News Reader
>> P.Schuman wrote:
>>> happen to run across this thread over on the Ethernet newsgroup -
>>> Some guy found a RJ45 splitter (2-RJ45 jacks to 1-RJ45 jack)
>>> over on ebay (search RJ45 spliiter) that look like the telco 1-line
>>> 2-line adapters,
>>> but yet this guy (and the ebay description) says these "splitters"
>>> .... Features:
>>> a.. Convert a single RJ45 outlet to two RJ45 sockets easily, point
>>> for more conveniently use
>>> b.. Increase the number of RJ45 network connections on an RJ45
>>> outlet c.. Compact design, feel free to enjoy your internet surfing
>>> d.. Expand one RJ 45 outlet into two 8 wire RJ-45 T adapter,
>>> parallel wiring
>>> e.. Connector: 3 x RJ45 female
>>> f.. 100% Brand New.
>>> It doesn't even seem possible to have more "network connections"
>>> by just splicing more Ethernet wires together vs a dumb hub ????
>>> I could see if you were trying to split out the tip/ring (4/5) or
>>> power (7/8)
>>> but an Ethernet splitter ?????
Posted by P.Schuman on March 28, 2008, 1:04 pm
AH HAH -
YES.... IF the description mentions that the pins are re-mapped,
then we have a solution -
BUT only if deployed in pairs.
I used to use them for piggyback of Phone + Ethernet + IBM 3270
on a single 8-wire RJ45 jack installed to each cubicle.
The original thread was basically using ONE of these "splitters"
to just walk up to any RJ45 jack, plug in - and now have TWO jacks and TWO
computers connected.
OR - using a "splitter" to run an Ethernet cable between several computers,
and basically T-connect them - as in the old coax days.
BTW - most of the eBay listings I clicked on made no mention of any
re-mapping,
so they might just be parallel RJ45's or ?? who knows what.
> pairs (pins 4,5,7 and 8) on the male end.
> Best Regards,
> News Reader
>> really - how ?
>> really - how ?
>> and 3/6 to be used ?
>> 1/2 = 1/2
>> 3/6 = 3/4
>> 1/2 = 5/6
>> 3/6 = 7/8
>>> option.
>>> Best Regards,
>>> News Reader
>>>> 2-line adapters,
>>>> .... Features:
>>>> point for more conveniently use
>>>> parallel wiring
>>>> f.. 100% Brand New.
>>>> power (7/8)
Posted by News Reader on March 28, 2008, 1:17 pm
The seller is not necessarily trying to deceive anyone.
Many products are promoted based on features, without any reference to
how to implement the functionality.
The eBay post was probably like most news posts, incomplete.
Best Regards,
News Reader
P.Schuman wrote:
> AH HAH -
> re-mapping,
>> Best Regards,
>> News Reader
>>> really - how ?
>>> really - how ?
>>> 1/2 = 1/2
>>> 3/6 = 3/4
>>> 1/2 = 5/6
>>> 3/6 = 7/8
>>>> option.
>>>> Best Regards,
>>>> News Reader
>>>>> 2-line adapters,
>>>>> .... Features:
>>>>> parallel wiring
>>>>> f.. 100% Brand New.
>>>>> power (7/8)
Posted by Robert Redelmeier on March 28, 2008, 3:13 pm
> jacks and TWO computers connected. OR - using a "splitter" to
> run an Ethernet cable between several computers, and basically
Yes, I remember a passive circuit for 10baseT that might
work under lucky conditions (short run, short patches).
No guarantees of any kind (including router port-burnout).
I doubt it would work at 100, and hubs are too cheap for
passive to be worth the risk.
-- Robert
Posted by on March 28, 2008, 2:51 pm
>Each device would utilize two of the four pairs within the 8-wire (e.g.:
>Cat 5e) cable.
>If you were utilizing GigEthernet, I believe all four pairs are used to
>support a single device, and therefore splitting would not be an option.
>Best Regards,
>News Reader
>> over on ebay (search RJ45 spliiter) that look like the telco 1-line 2-line
>> adapters,
>> but yet this guy (and the ebay description) says these "splitters" ....
>> Features:
>> a.. Convert a single RJ45 outlet to two RJ45 sockets easily, point for
>> b.. Increase the number of RJ45 network connections on an RJ45 outlet
>> d.. Expand one RJ 45 outlet into two 8 wire RJ-45 T adapter, parallel
>> wiring
>> f.. 100% Brand New.
>> I could see if you were trying to split out the tip/ring (4/5) or power
>> (7/8)
News has the right answer. These splitters break out the 4 pairs into
two sets of two. There is no problem with this in the ethernet
standard (cat 5 can support 2 ethernet lans if they are 10/100)
Don't do this with POTS phones unless you can live with the errors
when the phone rings.
It will not work with gigabit LAN, that needs all 4 pairs.
BTW I am doing this at my house and it works fine. (no packet errors)
Similar ThreadsPosted
RJ45 splitter for Ethernet - possible ? March 28, 2008, 11:56 am
Ethernet: which RJ45 pins? August 9, 2007, 9:49 am
best RJ45 crimper under $100? August 14, 2005, 3:27 pm
1 RJ45 to 4 BT converter? August 31, 2005, 3:18 pm
RJ45 connector question July 8, 2004, 2:55 pm
RJ45 to 110 Cross-Connects August 24, 2004, 1:13 am
DB25-to-RJ45 Adapters December 17, 2005, 8:04 pm
RJ45 connectors with a larger "gate"? September 22, 2004, 10:22 pm
RJ45 connectors with a larger "gate"? September 23, 2004, 9:59 pm
Corrosion in RJ11 / RJ45 Connectors April 14, 2005, 5:51 am
panel mounted RJ45 socket? August 9, 2005, 11:25 am
tool to ease RJ45 termination April 17, 2007, 11:13 am
Wiring on RJ45 wall socket July 8, 2007, 6:22 am
RJ45 Cat5e cables - male one one end, female (keystone) on other July 21, 2005, 3:48 pm
DIY Ethernet September 10, 2004, 8:57 pm
