Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by alex on September 23, 2004, 9:59 pm
Please log in for more thread options thanks for all your suggestions and info; much appreciated. i have found the L-com plugs that were mentioned and it looks like one of the varieties might just do the trick. as far as pre-made patch cables go...that is what we buy 95% of the time, but in certain situations we need the cable to be exactly the right length usually due to space considerations. moreover, sometimes we need 50'+ cables, and those are typically not so cheap. anyway, thanks again. take care, alex info_at_cabling-design_dot_com@foo.com (Dmitri(Cabling-Design.com)) wrote in | ||||||||||
| Similar Threads | Posted |
| RJ45 connectors with a larger "gate"? | September 22, 2004, 10:22 pm |
| RJ45 connectors with a larger "gate"? | September 23, 2004, 9:59 pm |
| Corrosion in RJ11 / RJ45 Connectors | April 14, 2005, 5:51 am |
| FS: AMP Lightcrimp Plus Termination Kit w/new SC connectors | August 3, 2005, 3:22 pm |
| How to crimp RCA connectors onto RG59 coax | July 11, 2006, 4:12 pm |
| CAT6 Requires Shielded Connectors? | August 19, 2006, 1:26 am |
| Installing S-n-S connectors on quad shield | August 30, 2007, 7:53 am |
| What's the right way to terminate RG6 Quad with F-Conn compression connectors? | January 20, 2005, 12:26 am |
| Transmit / Receive Assignments on fibe duplex connectors | December 29, 2004, 1:28 am |
| best RJ45 crimper under $100? | August 14, 2005, 3:27 pm |
| 1 RJ45 to 4 BT converter? | August 31, 2005, 3:18 pm |
| RJ45 connector question | July 8, 2004, 2:55 pm |
| RJ45 to 110 Cross-Connects | August 24, 2004, 1:13 am |
| DB25-to-RJ45 Adapters | December 17, 2005, 8:04 pm |
| Ethernet: which RJ45 pins? | August 9, 2007, 9:49 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> You sound like you are opening a business of making patch cords ;-). If
> that's the case, I suggest that you get one of those AMP/Tyco motorized
> crimpers, and while talking to the sales person, have them give all the
> info you need about the compatible plugs.
> If this is just an occasional patch cord making, I would suggest that you
> skip doing that and buy factory-made ones. These are REALLY cheap these
> days. A one-minute search on the Internet will yield dozens places where
> you can buy them for cheap with reasonable quality.
> Dmitri Abaimov, RCDD
> http://www.cabling-design.com
> Cabling Forum, color codes, pinouts and other useful resources for
> premises cabling users and pros
> http://www.cabling-design.com/homecabling
> Residential Cabling Guide
> Article posted with Cabling-Design.com Newsgroup Archive
> http://www.cabling-design.com/forums
> no-spam read and post WWW interface to your favorite newsgroup -
> comp.dcom.cabling,comp.dcom.lans.ethernet - messages and counting!
