LAN and Telecom Cabling RJ45 connectors with a larger "gate"?
Subject Author Date
RJ45 connectors with a larger "gate"? alex 09-22-04
Posted by alex on September 22, 2004, 10:22 pm
hello folks,
we have started purchasing CAT5e/6 and MediaTwist bulk cable for
making our own patch cables. however, with some (but not all) of the
CAT6 and MediaTwist cable we find it very hard to correctly terminate
the RJ45 modular plug because the entrance/gate to the plug is a
little narrow for the thicker cabling. this makes it hard to push all
the way into the jack and results in poorer connections.
can anyone suggest a RJ45 modular plug that might have a bigger cable
enterance to better accommodate thicker ethernet cable? i searched
around the web/usenet, but alas i didn't find anything specific to my
problem.
we are currently using a MilesTek crimper and Ideal Industries RJ45
plugs.
any info would be appreciated.
take care,
alex
Posted by Justin Time on September 23, 2004, 9:23 am
putt454@yahoo.com (alex) wrote in message
> hello folks,
> problem.
> plugs.
> take care,
> alex
I can't really understand why you are wasting the time and effort to
make patch cables by hand. Factory made patch cables are available in
bulk for as little as $2.50 for some of the more inexpensive ones. If
you figure the cost of the connectors, the cable and finally the labor
involved in making a 1 meter cable, it is probably more than the cost
of a bulk purchased cable.
Posted by on September 25, 2004, 1:04 am
Not to mention that commercial cables are far more reliable than
homemade ones.
-Larry Jones
Let's just sit here a moment... and savor the impending terror. -- Calvin
Posted by on September 23, 2004, 11:16 am
L-Com used to have a bunch of different options for square versus
rounded cable entrances to the plug, you might try them...
Look for "Radiused Cable Entrance", though they aren't Cat-n rated,
they might be able to find something that is, looks like they get the
Raduised stuff and their CAT6 stuff from Stewart Connector.
Posted by Dmitri(Cabling-Design.com on September 23, 2004, 7:41 pm
alex wrote:
> hello folks,
> problem.
> plugs.
> take care,
> alex
Hi Alex,
You sound like you are opening a business of making patch cords ;-). If
that's the case, I suggest that you get one of those AMP/Tyco motorized
crimpers, and while talking to the sales person, have them give all the
info you need about the compatible plugs.
If this is just an occasional patch cord making, I would suggest that you
skip doing that and buy factory-made ones. These are REALLY cheap these
days. A one-minute search on the Internet will yield dozens places where
you can buy them for cheap with reasonable quality.
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling,comp.dcom.lans.ethernet - messages and counting!
Similar ThreadsPosted
RJ45 connectors with a larger "gate"? September 22, 2004, 10:22 pm
RJ45 connectors with a larger "gate"? September 23, 2004, 9:59 pm
Corrosion in RJ11 / RJ45 Connectors April 14, 2005, 5:51 am
FS: AMP Lightcrimp Plus Termination Kit w/new SC connectors August 3, 2005, 3:22 pm
How to crimp RCA connectors onto RG59 coax July 11, 2006, 4:12 pm
CAT6 Requires Shielded Connectors? August 19, 2006, 1:26 am
Installing S-n-S connectors on quad shield August 30, 2007, 7:53 am
What's the right way to terminate RG6 Quad with F-Conn compression connectors? January 20, 2005, 12:26 am
Transmit / Receive Assignments on fibe duplex connectors December 29, 2004, 1:28 am
best RJ45 crimper under $100? August 14, 2005, 3:27 pm
1 RJ45 to 4 BT converter? August 31, 2005, 3:18 pm
RJ45 connector question July 8, 2004, 2:55 pm
RJ45 to 110 Cross-Connects August 24, 2004, 1:13 am
DB25-to-RJ45 Adapters December 17, 2005, 8:04 pm
Ethernet: which RJ45 pins? August 9, 2007, 9:49 am
