Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Brendon Caligari on July 17, 2004, 10:56 pm
Please log in for more thread options Hey At http://www.siemon.com there used to be some pretty cool videos on how to crimp and terminate various connections. Besides a crimper, a cable jacket stripper and a solid pair of scissors come in handy. I usually score (scratch) about 5cm of jacket and break it off. Undo the twist, straighten the connectors and aligned them according to T568-A or T568-B colour scheme as required. With the scissors i trim off the conductors at some 13mm away from the jacket and crimp. However, I prefer to use pre-fab multistrand patch cables. Brendon ++++ | |||||||||||||||||||||||||
| Similar Threads | Posted |
| RJ45 connector question | July 8, 2004, 2:55 pm |
| Connector ID request | January 16, 2005, 5:16 am |
| RJ11 connector | April 25, 2006, 11:21 am |
| WaveLAN antenna connector? | November 17, 2004, 1:20 pm |
| best RJ45 crimper under $100? | August 14, 2005, 3:27 pm |
| 1 RJ45 to 4 BT converter? | August 31, 2005, 3:18 pm |
| RJ45 to 110 Cross-Connects | August 24, 2004, 1:13 am |
| DB25-to-RJ45 Adapters | December 17, 2005, 8:04 pm |
| Ethernet: which RJ45 pins? | August 9, 2007, 9:49 am |
| RJ45 splitter for Ethernet - possible ? | March 28, 2008, 11:56 am |
| RJ45 connectors with a larger "gate"? | September 22, 2004, 10:22 pm |
| RJ45 connectors with a larger "gate"? | September 23, 2004, 9:59 pm |
| Corrosion in RJ11 / RJ45 Connectors | April 14, 2005, 5:51 am |
| panel mounted RJ45 socket? | August 9, 2005, 11:25 am |
| tool to ease RJ45 termination | April 17, 2007, 11:13 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Ok i just recently bought myself a crimping tool to crimp some CAT5
> cables with the connectors, now i am kind of practicing here until I
> get better at it. Now I have tried to do it on my own but so far none
> of the cables I did actually work so I dont know what I am doing
> wrong. This is what I am doing..
> I first strip the outer cat5 cable about 1/2 off the jacket, then I
> untwist the wires and arrange them properly, but first how do I make a
> even cut of the wires? I know you have to make them all even so when
> they go in the connector they all can hit the connector but I cant
> seem to make a straight cut, but moving on after that I put them in
> the connector and crimp it and thats it, but the ones I did dont
> work.. do you think maybe its because I didnt make an even cut?
