Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Lucas Tam on March 9, 2005, 5:45 pm
Please log in for more thread options The EDA-2100 is fine for cable modems and digital cable. The EDA-2100 has a uplink path (it's a bi-directional amp) that is compatble with digital services. I am running a EDA-2100 as well as a EDA-2400 for cable distribution in my house. The amplifiers are working fine with my digital cable service and cable modem as well. If you need to amplify your uplink, Electroline has a dedicated uplink amp as well. Also, FYI I believe Rogers Cable, one of Canada largest cable companies uses Electroline amps in their residential installs. P.S. You can buy Electroline amps really cheap on eBay. If you're not into eBay, RadioShack also carries bi-directional cable amps for a decent price. -- Lucas Tam (REMOVEnntp@rogers.com) Please delete "REMOVE" from the e-mail address when replying. http://members.ebay.com/aboutme/coolspot18/ | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Tomi Holger Engdahl on March 10, 2005, 2:16 pm
Please log in for more thread options >
> > Web page http://www.cabletvamps.com/Products/EDA-2100.htm says:
> > "The EDA-2100 is a 1-port amplifier. One port amplifiers are the > > easiest to install, and are best suited for connecting to your > > incoming cable line before you start splitting off the line to go to > > multiple TVs. The EDA-2100 is generally the best for use in existing > > installations, since it is easy to use, with a single cable connection > > in and out." >
> The EDA-2100 is fine for cable modems and digital cable. The EDA-2100 > has a uplink path (it's a bi-directional amp) that is compatble with > digital services. > > I am running a EDA-2100 as well as a EDA-2400 for cable distribution in > my house. The amplifiers are working fine with my digital cable service > and cable modem as well. Thank you for clearing out this... I had no experience in using that EDA-2100 amplifier. I based my answer on the information found on the given web page address. And that information web page did not specify that is indeed bidirectional amplifier. The product web page could have been more informational on this... I only later found te comparision page at http://www.cabletvamps.com/comparison%20chart.htm that gives some more information. -- Tomi Engdahl (http://www.iki.fi/then/) Take a look at my electronics web links and documents at http://www.epanorama.net/ | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Lucas Tam on March 10, 2005, 11:57 pm
> given web page address. And that information web page > did not specify that is indeed bidirectional amplifier. > The product web page could have been more informational > on this... Actually it does specify it's bi-directional ; ) Return Passband 5-42 MHz 5-65 MHz In esscence all bi-directional amps forward these frequencies back to the headend. Non bi-directional amps don't have a return bandpass : ) -- Lucas Tam (REMOVEnntp@rogers.com) Please delete "REMOVE" from the e-mail address when replying. http://members.ebay.com/aboutme/coolspot18/ | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Ed Nielsen on March 10, 2005, 11:26 pm
In the USA, it's 5-42MHz. A 5-65MHz amp would be absolutely useless. CIAO! Ed N. Lucas Tam wrote: > Actually it does specify it's bi-directional ; )
> > > Return Passband 5-42 MHz > 5-65 MHz > > In esscence all bi-directional amps forward these frequencies back to the > headend. Non bi-directional amps don't have a return bandpass : ) > | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Tomi Holger Engdahl on March 11, 2005, 11:41 am
To my knowledge 5-65 MHz is used on some cable TV networks in Europe. I think HTV in Finland uses it, at least at some parts of it's network. Having more bandwidth for return channel allows more bidirectional traffic in the network. > CIAO!
> > Ed N. > > Lucas Tam wrote: > > Actually it does specify it's bi-directional ; )
> > Return Passband 5-42 MHz > > 5-65 MHz In esscence all bi-directional amps > > forward these frequencies back to the headend. Non bi-directional > > amps don't have a return bandpass : ) > > -- Tomi Engdahl (http://www.iki.fi/then/) Take a look at my electronics web links and documents at http://www.epanorama.net/ | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Need help identifying cable - RG59 or RG-6 | July 25, 2006, 11:23 am |
| How to crimp RCA connectors onto RG59 coax | July 11, 2006, 4:12 pm |
| Convert old Coax RG59/6 to Cat 5 while wiring house -- possible? | September 4, 2004, 2:16 pm |
| RG-59 & Amplifier? | March 9, 2005, 2:25 am |
RG-59 & Amplifier?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> in and out."
> This kind of ampliifer sound somethign that is OK for splitting
> the incomign antenna signal to different TVs.
> What in you case complicates thigns is that you say you have cable
> modem. A cable modem will not work through a normal antenna
> booting amplifier.
