LAN and Telecom Cabling RG-59 & Amplifier?
Subject Author Date
RG-59 & Amplifier? Crypt 03-09-05
---> Re: RG-59 & Amplifier? Tomi Holger Eng...03-09-05
Posted by James Knott on March 9, 2005, 12:35 pm
Crypt wrote:
> Also about the cable modem.  If I put the EDA-2100 before the cable modem
> (I'm thinking maybe where the cable line first comes in to the house) is
> there any chance it could help the cable modem maintain connectivity?
No. In fact it will make it unusable. Any amp ahead of the modem has to be
able to pass the data transmitted by the modem.
Posted by Lucas Tam on March 9, 2005, 5:46 pm
>> modem.ÿÿIfÿIÿputÿtheÿEDA-2100ÿbeforeÿtheÿcableÿmodem (I'm thinking
>> maybe where the cable line first comes in to the house) is there any
> to be able to pass the data transmitted by the modem.
That's untrue - the EDA-2100 is a bidirectional amp that is compatible with
digital cable services.
Rogers Cable uses the EDA in some installs... and they place it right in
the cable box OUTSIDE your house ; )
Lucas Tam (REMOVEnntp@rogers.com)
Please delete "REMOVE" from the e-mail address when replying.
http://members.ebay.com/aboutme/coolspot18/
Posted by Lucas Tam on March 9, 2005, 5:45 pm
> modem (I'm thinking maybe where the cable line first comes in to the
> house) is there any chance it could help the cable modem maintain
> connectivity?
Yes, if your signal is weak this will help.
The EDA-2100 is compatible with digital cable services (it's a bi-
directional amp) so it shouldn't affect your cable modem too much.
If you need a return path boost, check out the ERA-4100.
As for your question about what type of cabling you should use, it's best
to run RG-6 Dual Shielded or RG-6 Quad shielded for digital
satellite/cable.
Posted by Crypt on March 9, 2005, 2:26 am
Also the Electroline amp I'm thinking of getting is model EDA-2100.
Posted by Tomi Holger Engdahl on March 9, 2005, 1:22 pm
Web page http://www.cabletvamps.com/Products/EDA-2100.htm says:
"The EDA-2100 is a 1-port amplifier. One port amplifiers are the
easiest to install, and are best suited for connecting to your
incoming cable line before you start splitting off the line to go to
multiple TVs. The EDA-2100 is generally the best for use in existing
installations, since it is easy to use, with a single cable connection
in and out."
This kind of ampliifer sound somethign that is OK for splitting
the incomign antenna signal to different TVs.
What in you case complicates thigns is that you say you have cable
modem. A cable modem will not work through a normal antenna
booting amplifier. The reason is that normal antenna
signal amplifiers are unidirectional, pass signal only to
one direction and amplify signal on the way.
The cable modem uses two way communications over cable TV cable
(at least all modern systems). If you put an unidirctional
amplifier on the way, the downstream signal gets through
amplified, but the signals the cable modem sends out never
get to the cable company end becasue the amplifier blocks them.
The cable TV systems that support cable TV use bidirectional
amplifiers designed for two way commications in mind.
Those amplifiers will amplify normal TV frequencies normally
as any norma maplifier, but in addition to it they will
pass the return signals (frequencies from 5 MHz to 30..60 MHz
depending on system) on the opposite direction.
This is accomplished with a special filter inside amplifier unit
and possibly another amplifier to amplify the return channel
signal. This kind of bidirectional amplifiers are available,
but their market is generally more to cable TV companies
than to consumers.
Tomi Engdahl (http://www.iki.fi/then/)
Take a look at my electronics web links and documents at
http://www.epanorama.net/
Similar ThreadsPosted
Need help identifying cable - RG59 or RG-6 July 25, 2006, 11:23 am
How to crimp RCA connectors onto RG59 coax July 11, 2006, 4:12 pm
Convert old Coax RG59/6 to Cat 5 while wiring house -- possible? September 4, 2004, 2:16 pm
RG-59 & Amplifier? March 9, 2005, 2:25 am
