LAN and Telecom Cabling Question on getting proper spec cable installed from the pole to the house
Subject Author Date
Question on getting proper spec cable installed from the pole to the house rogacasa 08-08-06
Posted by on August 8, 2006, 1:04 pm
Hi. I'm getting cable modem service soon. I have rewired my entire
house with Belden 1694A cable. So all of the cable in my house is now
RG-6, all the way out to the grounding block outside in the gray cable
company box.
What has NOT been upgraded is the cable line coming from the pole to
the house. I inspected it, and found these numbers on the long main
section:
BELDEN 9059 DUOBOND PLUS CATV COAX 18AWG 75OHM QE
Tacked onto this, there is also a shorter (about 6 to 10 feet) section
of cable with this numbering:
MEDIAONE E83032 F6SSVV-CRD CATV
As far as I've been told, the stretch of Belden 9059 is NOT RG-6 spec.
If that is the case, I want a NEW RG-6 cable line from the pole to the
house.
I can get cable modem service activated entirely through the Comcast
website, but I think I need to call Comcast and arrange for a service
tech to come out and replace the cable from the pole to the house.
Right?
What is the right way to do this? Just call? When dealing with
customer service, what are the right things I need to say to get this
work done?
Thanks,
Roger Carlson
Posted by Kenneth J. Harris on August 8, 2006, 3:12 pm
I don't have Comcast, so I can only tell you what my cable service
provider will do, based on my experience. If you call to subscribe,
they will make a service(installation) call. They prefer that someone
be at home. They inspect the cable and if they find the cable drop not
up to par(not the current cable type they use, spliced, etc.) they will
replace it with new stuff. If you are home and point out the cable
problems they will replace it with new stuff. They will check the signal
where it enters the house and then the reception at the tv in the house.
If all is good/within specs, that's it.
Ken
> company box.
> section:
> house.
> Right?
> work done?
> Thanks,
> Roger Carlson
Posted by DLR on August 8, 2006, 3:51 pm
> company box.
> section:
> house.
> Right?
> work done?
Wrong. What they are selling and you are buying is a signal/service, not
a cable. If the signals meet spec, they'll leave your current cable. If
not, they'll replace it. Now a decent installer will be willing to look
at what's there and if he has time and it's easy and he feels it will be
a problem soon, he might replace it. Or not.
Posted by Agent_C on August 8, 2006, 4:30 pm
Humm, sounds like offering the installer a sexual favor might be in
order.. How important is this to you?
A_C
Posted by DLR on August 8, 2006, 6:38 pm
Actually I'd definitely bring out a tall glass of ice and offer water or
soda. Nothing that would get them fired.
Similar ThreadsPosted
Question on getting proper spec cable installed from the pole to the house August 8, 2006, 1:04 pm
When was teh CAT-3 spec for cable finalized? April 18, 2006, 7:29 am
Proper, clean cable management (howto) May 18, 2007, 11:47 am
Supply 2 Pole,3 Pole Gas Tube Surge Arresters,Gas Discharge Tube,(Ceramic Surge Arresters February 11, 2006, 3:25 am
Completely weird cable problem in new house - need insights pls! November 8, 2006, 9:50 am
Re: Proper way to install shielded (STP) Ethernet August 11, 2006, 5:25 pm
Re: Proper way to install shielded ethernet August 13, 2006, 12:07 pm
Bergstrom Manufacturing "The Pole" vs. Fiberfish & others May 26, 2006, 8:44 pm
Network in new house June 12, 2005, 6:48 pm
Wiring new house February 11, 2006, 11:45 pm
Whole-house lightning/surge protection ? July 8, 2006, 11:16 am
Convert old Coax RG59/6 to Cat 5 while wiring house -- possible? September 4, 2004, 2:16 pm
Re: Ethernet via house telco twisted pairs December 28, 2008, 11:22 pm
Question about Cat 7 cable February 1, 2005, 2:03 pm
Cable Substitution Question March 6, 2006, 10:50 am
