LAN and Telecom Cabling Question about Cat 7 cable
Subject Author Date
Question about Cat 7 cable reellifetv@hotmail.com 02-01-05
Posted by Watson A.Name - \"Watt Sun, th on February 6, 2005, 12:06 pm
> I'm about to wire up my house, and have decided to run Ethernet cable
> pretty much everywhere, using it for both data and audio.
> Was originally going to use cat 5, but have instead settled on Cat 7
> (which in the UK only appears to be available from Canford). It will
> cost quite a lot more, but it's not often I have all my floorboards
> up, and I'd like to future-proof as much as I can!
If you really want to future-proof, you should run flex or conduit, and
thus leave yourself the option of putting fiberoptic cable at a later
date. That is if you really want the future. But it's likely that the
legacy copper will still be around and fully useable for decades to
come.
> My plan was to run the cat 7 to deep single- and double-gang metal
> boxes, to which I'd attach Canford connector plates with holes that
> will take either XLR, BNC, phono or BNC sockets. This way I have
> flexibility over what to feed to different locations.
> One concern is that Cat 7 uses solid core rather than stranded
> conductors - will this create problems in connecting to the various
> sockets? I've seen reference to needing to connect using a punchdown
> block, and I'm not sure how this would work in the setup I'm
> envisaging.
> This is a bit of a leap into the dark for me, representing quite a big
> investment plus a real headache if I put it all in, replaster my walls
> and lay the floors, only to find it doesn't work, so I'd be very
> keen for any thoughts.
> Many thanks,
> Chris
Posted by Al Dykes on February 6, 2005, 3:32 pm
>come.
>> envisaging.
>> Many thanks,
>> Chris
I strongly suggest that you plan the location point(s) for WiFI APs to
cover the entire house and pull CAT5 to those points. You don't have
to buy APs until you need them. They will get their power over the
ethernet cable (aka POE). These can be closets or attic locations
that you would not otherwise think to pull cable to.
A good "g" signal gives you lots of speed and IMO will be useful in
the future as more gadgets come out. Right now it lets you put a
printer anywhere you have 120VAC.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Similar ThreadsPosted
Question about Cat 7 cable February 1, 2005, 2:03 pm
Cable Substitution Question March 6, 2006, 10:50 am
Fiber optic cable question September 20, 2006, 5:48 pm
Question on getting proper spec cable installed from the pole to the house August 8, 2006, 1:04 pm
Fiber question November 16, 2004, 6:24 pm
Telephone question October 23, 2004, 12:23 am
10BaseT Question December 29, 2005, 3:44 pm
Re: newbie cat 5 question! May 29, 2008, 3:35 pm
RJ45 connector question July 8, 2004, 2:55 pm
newbie cabling question August 24, 2004, 3:17 pm
Yet another price per drop question January 10, 2005, 1:08 am
66/110 blocks - newbie question May 18, 2005, 12:35 pm
DSL router cabling question February 8, 2006, 12:53 pm
Powerline Networking Question March 2, 2006, 10:39 am
10Base2 Resistance Question July 5, 2006, 2:56 pm
