Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Dmitri(Cabling-Design.com on October 5, 2004, 6:37 am
Please log in for more thread options > Dmitri(Cabling-Design.com wrote:
>> Don't know if that was true or not, but it
>> made sense to me when I read it. > It's the first I've heard of it, and I've spent 23 years in the telcom
> industry. There are a lot of things that "make sense", but > are in fact > fiction. > Also, I don't recall AT&T being much in the local lan business.
> Phone > cables are capable of much greater distances. I was referring to the PDS (later SYSTIMAX) unit of AT&T. These guys have a lot to do with LANs and little with traditional telecom. But I do admit there might be a great deal of urban legend here. -- Dmitri Abaimov, RCDD http://www.cabling-design.com Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros http://www.cabling-design.com/homecabling Residential Cabling Guide ------------------------------------- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.cabling - 4662 messages and counting! ##-----------------------------------------------## | |||||||||||||||||||||||||||||||
Posted by Justin Time on October 5, 2004, 4:29 pm
> >> It just doesn't make sense: to accommodate for all possible
> >> combinations > >> of lengths that a pair of Ethernet devices may encounter (from 0 > >> to 100 > >> meters), the devices are designed to hold the data received in the > >> buffer > >> memory for at least the duration of the longest trip - 100 meters. > >> Therefore, any measurement you might be able to take this way > >> (without > >> arguing whether it's even possible to measure such tiny time > >> interval with > >> devices not specifically designed for that) will always show one > >> length - > >> 100 meters (295 ft) >
> > Actually, the longest trip may be far greater than 100 M. For example,
> > on > > 10base5 network, the maximum distance is 500M and fibre can go much > > further > > than that. Also even with CAT5 on a switch, you can go 200M etc. > > Ethernet, being a level 2 protocol, will make sure the packet gets > > placed > > on the wire, without experiencing a collision. Once 512 bits have been > > transmitted, it's considered collision free and the ethernet portion of > > the > > stack has no more concerns about the data, such as if it made it to the > > destination intact. It then becomes the responibililty of a higher > > layer > > (either TCP or the application, if UDP) to ensure end to end integrity. >
> > UDP apps might not worry about that.
> > The 100M CAT5 limitation is due entirely to signalling limits and has
> > nothing to do with collision detection etc. >
> I agree with you, James. > I was trying to make a point that any delay that actually has anything to > do with the real cable length (no matter how small or long of a delay) > will essentially be "normalized" to the maximum allowable limit on the > hardware level. > > Also, being a cable guy I am, I have another, fully "passive physical > level", explanation of the 100 meter cable length limit: > As read in a source that cannot recall the name or origins of, some 25 > years ago AT&T commissioned a survey of about 1000 (OK, make it any > statistically significant number - I don't recall the actual number > anyways ;-)) commercial buildings in the US to find out that more than 80% > of the useable spaces in the buildings surveyed can be reached by a cable > that's 100 meters long from the telecom closet. Thus they decided to stick > with the length as being a nice rounded figure, and the electrical > characteristics have been maxing out at that length ever since. The > electronics components manufacturers in turn had to work around the > electrical characteristics limit to make sure the equipment will work on > the installed base of cable. Don't know if that was true or not, but it > made sense to me when I read it. > > -- I don't know if your story is true or not, but I was with Datapoint for 10 years, from 1978 till 1988. It was in 1976 that Datapoint introduced ARC or the Attached Resource Computer, a networking system that ran on 92 ohm coax. This was a token-passing system or more properly CSCA Carrier sense, collision avoidance unlike Ethernet's CSCD carrier sense, collision detection. ARCnet ran at 2.5 mbps and was a very robust system for its time. It was around 1981 or 82 the Norwegians (or was it the Swedes - even possibly the Finns) were redoing their national infrastructure and beginning to deploy data networks throughout the country. It was their intent to become a "cashless" country allowing a credit card or key to automatically debit a person's bank account for any type of purchases. Being unable to wire the country with coax - fiber was still a laboratory toy - they developed media converters to change from a coaxial cable based system such as the IBM 3270, Wang and even Datapoint to run over regular telephone cable. Because telephone cable varied in guage, twist or lay, insulation types and any other number of variables including DC resistance, the practical distance was set more by the physical and electrical limitations of the cable in use rather any "standard distance to wire a floor." It wasn't too long after this that IBM developed their specification for running Token Ring over UTP. The G21 spec as I referred to it (the first letters of the spec were G21-) required the twisted pair cable to meet certain specifications as far as capacitance, DC resistance, guage and other requirements in order to carry the 4Mb signal. Again, the type of insulation, capacitance, resistance and other factors limited the distance the cable could carry a usable signal. It wasn't until '91 or so that Cat 3 came about and I referred to the earlier G21 spec cable as Cat 2 1/2 - it would work, but not always well or at longer distances. The insulation also had a lot to do with it. This is all pretty much before plenum cable and teflon insulations, so we were dealing with pvc and other types of plastic. The equipment used to manufacture cable also didn't have the tolerances that are commonplace today so you could get marked variations in cables from the same manufacturer off cable making machines that were side-by-side. Even from the same machine as different spools of copper were loaded or a new batch of plastic added to the extruders. From my experience, the 100 meters had a lot more to do with the physical and electrical limitations of the copper cable rather than any "standard cable run" ever had. If you actually go back and can dig up a '91 edition of the 568 standard or even TSB-40 or 40A I think you will see that Token-ring ran distances greater than Ethernet on the same cable. Rodgers Platt | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Program to Estimate Cat 5 Cable Length | October 1, 2004, 4:52 pm |
| Cable length | July 18, 2006, 9:43 pm |
| Minimum 10Base100 Cable Length | July 16, 2004, 9:32 am |
| Power + DSL signal in same 700ft cable length | October 12, 2006, 6:35 pm |
| OTDR: Launch Cable Length for Singlemode | April 10, 2008, 2:50 pm |
| Re: Ethernet connection sensitive to cable length | May 3, 2008, 12:37 pm |
| Cabling length | December 1, 2005, 4:47 am |
| Average Length of Cat5 Run | August 25, 2004, 10:21 am |
| Maximum Length for 1000Base-SX | September 15, 2006, 2:25 pm |
| Looking for 2 MM LC-LC fiber cables 30m to 50m in length-surplus/cheap | October 6, 2004, 1:48 am |
| OTDR: Launch Cable; Receive Cable | April 10, 2008, 2:46 pm |
| Can I use a CAT5 cable as a TV Coax cable? | October 14, 2006, 2:13 pm |
| Which end is bad of cable | July 7, 2005, 10:51 pm |
| Cable Managers - 1U vs 2U | August 12, 2004, 11:01 pm |
| Re Cable Managers - 1U vs 2U | August 13, 2004, 10:28 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
