LAN and Telecom Cabling Prefered metod to attatch racks to floor ?
Subject Author Date
Prefered metod to attatch racks to floor ? Sonto 03-09-05
Posted by Sonto on March 9, 2005, 3:13 pm
Anyone have any pros or cons to shooting racks to a concrete floor with a
hilti ?
Posted by James Knott on March 9, 2005, 7:26 pm
> hilti ?
The company I used to work for used a Hilti drill & anchors, to secure racks
to the floor.
Posted by Robert Redelmeier on March 9, 2005, 9:53 pm
> concrete floor with a hilti ?
I'd want to use threaded stud nails. Can be screwed
down if the nail doesn't penetrate enough (irregular/old
concrete), and can be unscrewed to remove rack.
-- Robert
Posted by Michael Quinlan on March 9, 2005, 10:36 pm
I usually use tapcon screws (hex head) with an appropriate washer (if
needed). If you go this route, I recommend blowing out the holes with
compressed air before installing the screws. The tapping action of the
screws tends to build up debris in the holes, and the screws can bottom
out before they go in all the way.
Posted by Dmitri(Cabling-Design.com on March 10, 2005, 6:28 am
> with a
> hilti ?
Chances are you may have to move the racks later. People add racks,
vertical wire managers, do all kinds of re-arrangements in their telecom
rooms. You would have more options if you've opted to use less permanent
way of immobilizing the racks.
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling - 1468 messages and counting!
Similar ThreadsPosted
Prefered metod to attatch racks to floor ? March 9, 2005, 3:13 pm
Modular Furniture Floor Mounted Boxes August 25, 2005, 12:40 pm
