Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Watson A.Name - \"Watt Sun, th on May 8, 2005, 6:26 pm
Please log in for more thread options > wall that won't cost me a fortune.
> > Thanks! > > -Mike The Avaya and Systimax patch panels we've been using are about $150 for 24 ports, even more for 48. If you want to go cheap, just buy four 8-port faceplates and put wall jacks in them. But in out case, Systimax jacks are $5 apiece si ot adds up to about the same price. You could go with the patch panel for the first 24, then add a 6-port faceplate for about $30 more. | ||||||||||||||||||||||||||||
Posted by johnr999@aol.com on May 8, 2005, 7:00 pm
Please log in for more thread options Another way to go cheap might be www.netcablesplus.com which lists a 24-port Cat 5e patch panel for under fifty bucks. I have not yet purchased from them, but a colleague mentioned them to me. Apparently, he has been very pleased with their products. -John | ||||||||||||||||||||||||||||
Posted by Steve Harvey on June 8, 2005, 11:14 pm
forman.mike@gmail.com wrote: > I have a new house which I have about 30 runs of cat5 going to my
> termination point (my garage). > > I'm looking for recomendations on a patch panel that I can mount to the > wall that won't cost me a fortune. > > Thanks! > > -Mike Try Panduit.com The company I work for,install these things by the hundreds, they work very well and can be purchased at most supply houses for reasonable prices. My personal preference is the Siemon High density 110 type, universal patch panels, buy a wall mount bracket to go with and proceed | ||||||||||||||||||||||||||||
Posted by Justin on June 9, 2005, 1:13 pm
Steve Harvey wrote: >
> forman.mike@gmail.com wrote: > > >>I have a new house which I have about 30 runs of cat5 going to my
>>termination point (my garage). >> >>I'm looking for recomendations on a patch panel that I can mount to the >>wall that won't cost me a fortune. >> >>Thanks! >> >>-Mike >
With 30 runs, you have many options that you could go with. One would
> > Try Panduit.com The company I work for,install these things by the > hundreds, they work very well and can be purchased at most supply houses > for reasonable prices. > My personal preference is the Siemon High density 110 type, universal patch > panels, buy a wall mount bracket to go with and proceed > be to use a wall mount, swing bracket from AllenTel, then any 48 port Cat5e patch panel would work. Panduit is my preference, but Leviton, Hubbell, Siemon, Ortronics all would be ok choices. There are many cheaper brands that you could find, especially at Cable-R-Us type places, but the quality I believe leaves much to be desired. And I'm sure those types are also just barely get past performance specs, so I wouldn't put too much trust in them. Anyway, look at the above manufactures websites, and you see many of your options. Several have panels that will mount directly to the wall without the swing out rack. | ||||||||||||||||||||||||||||
Patch panel reccomendation
Yahoo!
Windows Live
del.icio.us
digg
Netscape
