LAN and Telecom Cabling Patch Vs. Crossover Cables
Subject Author Date
Patch Vs. Crossover Cables Tony 03-09-06
Posted by Tony on March 9, 2006, 11:18 am
Hi everyone,
Can some people chime in as to whether or not patch cables are the same
as crossover cables? Are they or are they not the same? If you do not
already know the answer I would prefer you not respond. Please do not
look on Google to get your answer. :)
I recently bought three crossover cables from ComputerCableStore.com.
When the cables arrived I found they were actually patch cables, not
crossover cables. When I e-mailed the customer service person about the
problem she insisted that "patch" is just another term for "crossover".
In other words, ComputerCableStore.com is claiming there is no
difference between patch and crossover cables.
I'm not an Ethernet expert but I'm pretty sure (about 99.9%) that
crossovers are different from patch. Is it true or is the customer
service person from ComputerCableStore.com correct?
Thanks.
Posted by Al Dykes on March 9, 2006, 11:26 am
>Hi everyone,
>Thanks.
""patch" is just another term for "crossover"" is incorrect.
Crossover cables are wired differently but look identical to patch
cables. Every factory-made crossover cable I ever seen was clearly
labeled as such. If it doesn't say "crossover", it's probably not
one.
Patch cables are wired "straight through". Crossover cables have signals
crossed.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Posted by DecaturTxCowboy on March 9, 2006, 1:29 pm
Two different definitions here, one is a generic usage description
("patch cable") and one is wiring (pin out) scheme description
("cross-over").
A patch cable just a phrase to describe the usage of a short cable. It
does not specify the wiring scheme, i.e. straight-through or cross-over.
It is usually a short 3 ft. cable that connects two devices together,
such as the house cable termination patch panel to a hub or switch
located in your equipment room, as opposed to the cabling inside the
wall (house cable) or from office wall jack to the computer NIC (you
could usually just call this the network cable to the computer).
These cables use a straight-through wiring scheme in that both cable
ends and jacks are wired identically. It doesn't matter what wiring
scheme or jack standard you use, 568A or 568B, just as long as the same
standard is used through out the wiring plan.
There is one exception where you might need a cross-over patch cable. A
cross-over cable is where the pins 1 and 2 are swapped with pins 3 and
6. Basically the cable has a 568A wiring scheme on one end and 568B on
the other. This is often used for the cable from a DSL modem to the
internet jack of a router or uplink jack between two hubs, or for
connecting only two computers together in an simple "network".
So to answer your question...99.9% of patch cables are straight-through,
the .1% exception is when you really need a crossed over cable.
Therefore the customer service answer in the context you described would
be incorrect.
Look at the two ends of the cables you bought. If pin 2 is the same
color on both cables, you have a straight through patch cable. It will
most likely be orange/white 568B), but may be green/white 568A). *IF*
pin 2 is green/white on one end and orange/white on the other end, then
you have a cross-over patch cable which is not what you'll be wanting to
use. BTW, I used pin 2 for my example as its easier to see the colors
compared to pin 1.
Posted by dg on March 14, 2006, 4:28 pm
> These cables use a straight-through wiring scheme in that both cable ends
> and jacks are wired identically. It doesn't matter what wiring scheme or
> jack standard you use, 568A or 568B, just as long as the same standard is
I am a firm believer that you should go with either 568A or 568B throughout
an entire installation, not a mix. But tell me this, is there really any
technical problem with using 568A patch cables in a building that is wired
to the 568B standard? I mean, permanent in-wall cabling is all terminated
568B but you use patch cables that are 568A?
Or the other way around, the permanent cabling is terminated 568A but you
use patch cables that are 568B?
It seems to me that no problem should be caused by this, and I wouldn't want
to do it just because I like to keep things simple to avoid complications
down the road. But what do you guys think? Should there be any problem?
THANKS!
--Dan
Posted by DecaturTxCowboy on March 14, 2006, 9:17 pm
There's nothing wrong doing that at all. Consider all the government
house cabling jobs done with the 568A standard and then using 568B patch
cables and jack to computer cables.
Since the patch cables are pre-made, the only thing YOU would need to
make sure is that the wall jacks are wired to same standard as you
equipment room patch panel jacks.
Similar ThreadsPosted
Patch Vs. Crossover Cables March 9, 2006, 11:18 am
Long patch cables vs. patch panel August 18, 2004, 9:21 pm
Short Patch Cables March 3, 2006, 4:08 pm
Brand Names for CAT6 Patch Cables July 22, 2006, 9:37 pm
Crossover cable, not working (Kind of) December 7, 2004, 7:16 pm
Duplex LC-LC Jumper Cable - How to convert to crossover? August 10, 2005, 2:11 pm
Sell Cat5e Modular Patch Panels,AMP Network Modular Patch Panels,Panduit Patch Panels,Mini-Com Shielded Modular Patch Panels March 15, 2006, 8:28 am
Available USB Cables February 13, 2007, 3:32 pm
V.35 cables anyone? January 17, 2008, 12:49 am
tracing cables May 9, 2006, 4:54 pm
Sell Cat5e FTP Patch Panels,Cat 5e FTP Patch Panels,Cat5e Shieldes Patch Panels March 15, 2006, 8:23 am
Any way to organize cables that weren't labeled? February 23, 2006, 11:32 am
Serial Cables - which cable should I use? February 26, 2006, 6:31 pm
Organising network cables May 4, 2006, 3:38 am
LC Dual mode fiber cables, I need some help/info September 28, 2004, 7:25 pm
