Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by James Knott on April 27, 2005, 9:52 am
Please log in for more thread options alodoiska wrote: There some places that use power line distribution, but there's a severe interference problem with licenced radio spectrum users. >
> My area is a combination of urban area with narrow streets and highways > in between. > > Antony | ||||||||||||||||||||||||||||||||||||||||
Posted by Justin T. Clausen on April 27, 2005, 11:24 am
Please log in for more thread options alodoiska wrote: > Dear James,
I've heard rumors about a new fiber optic cable that is installed in the
> > What are new ways, what about electric utility network or else? > > My area is a combination of urban area with narrow streets and highways > in between. > > Antony > asphalt, similar to the sensors for stop lights. Cut a grove in the asphalt, lay in the fiber, re-fill the asphalt. But I've never seen it, or looked it up, so you're on your own there. JT | ||||||||||||||||||||||||||||||||||||||||
Posted by James Knott on April 27, 2005, 10:23 pm
Justin T. Clausen wrote: > I've heard rumors about a new fiber optic cable that is installed in the
> asphalt, similar to the sensors for stop lights. Cut a grove in the > asphalt, lay in the fiber, re-fill the asphalt. But I've never seen it, > or looked it up, so you're on your own there. Given some of the roads around here, I'd be worried about fibre breaks. Incidentally, a company I used to work for, ran fibre along side railroad tracks. It worked fine, except for one day, when a large sink hole appeared under one side of the track, and took out the fibre. Then there's always "backhoe fade". ;-) | ||||||||||||||||||||||||||||||||||||||||
Posted by Justin T. Clausen on April 28, 2005, 7:57 pm
>>asphalt, similar to the sensors for stop lights. Cut a grove in the >>asphalt, lay in the fiber, re-fill the asphalt. But I've never seen it, >>or looked it up, so you're on your own there. >
I think I've seen pictures of that. Did the Lightbrigade company show
> > Given some of the roads around here, I'd be worried about fibre breaks. > Incidentally, a company I used to work for, ran fibre along side railroad > tracks. It worked fine, except for one day, when a large sink hole > appeared under one side of the track, and took out the fibre. Then there's > always "backhoe fade". ;-) > > up at that break? Yeah, I'd have issues with the road conditions as well. I would think it would have to be in highly urban areas as those roads seem to get the most attention. | ||||||||||||||||||||||||||||||||||||||||
Posted by laginikoro_a on April 29, 2005, 5:48 am
Hi alodoiska, here in Fiji Islands, we have 2 companys [i.e Telecom] which both uses fiber optic. one has an advantage, they have underground pipes telecom chambers and all but the other dont but they have electrical post. so what the latter company did is that they run their cables from electrical post to post and they have now more advantage than the former compnay [underground]. this is only a suggestion. thank you ------------------------------------- alodoiska wrote: > Hello everybody,
> I would be grateful if someone could upgrade my knowledge on new
> techniques to lay down fiber cable in urban areas, either in sewerage, > water conduit or directly in their own protective duct. > Are there any new techniques which enable minimum digging and damage to
> streets and urban facilities to lay down fiber optic cable? > Thanks,
> Antony
##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.cabling - 1836 messages and counting! ##-----------------------------------------------## | ||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| New techniques | April 26, 2005, 7:37 am |
New techniques
Yahoo!
Windows Live
del.icio.us
digg
Netscape
