LAN and Telecom Cabling Need RG6qs?
Subject Author Date
Need RG6qs? danno 02-04-05
---> Re: Need RG6qs? t568aort568b02-04-05
Posted by danno on February 4, 2005, 1:56 pm
I am finishing my basement and just finished the wiring when I learned
that there is more than one kind of RG6 (the stuff I bought at Home
Depot is the garden variety type, not quad shield).
I have a 30 ft. run of rg6 that runs alongside one standard phone wire
and one cat5 line; at one point it crosses near a 12/2 120 v romex ac
line in a stud (perpendicular, not parallel). I brought the rg6 as
close to the front of the stud as possible to keep it away from that ac
line.
Do I need to rewire with quad shield rg6 to avoid interference? Or
should standard rg6 do the job??? Right now, I'm just using analog
cableTV, but one day will probably want HDTV.
Thanks for any advice you might have,
Danno
Posted by on February 4, 2005, 5:52 pm
If your 12 inches away from power you will be fine.
Posted by danno on February 4, 2005, 6:15 pm
Actuallly, it's only 2 inches away, but the lines are not parallel. AC
is line going horizontally thru the stud; rg6 is coming down the side
of the stud vertically (ceiling to floor).
Will this create a problem?
Posted by Ed Nielsen on February 4, 2005, 9:56 pm
You should be fine.
CIAO!
Ed
Posted by Lucas Tam on February 5, 2005, 6:26 am
@g14g2000cwa.googlegroups.com:
Nope, it should be fine. In reality, power doesn't create that much
interference.
Lucas Tam (REMOVEnntp@rogers.com)
Please delete "REMOVE" from the e-mail address when replying.
http://members.ebay.com/aboutme/coolspot18/
Similar ThreadsPosted
Need RG6qs? February 4, 2005, 1:56 pm
