LAN and Telecom Cabling Miswired Cable Works?
Subject Author Date
Miswired Cable Works? Michael Quinlan 05-10-05
|--> Re: Miswired Cable Works? Robert Redelmei...05-10-05
`--> Re: Miswired Cable Works? Dmitri(Cabling-...05-10-05
Posted by glen herrmannsfeldt on September 20, 2005, 12:52 am
David Lesher wrote:
>>What do you mean by "reversed pairs", if not cross over? It doesn't matter
>>what colour the wires are, so long as proper pairing is maintained.
> At one end, the blue-white is punched down where the white-blue
> should be and vice versa.
10baseT does need the right polarity, but as far as I know it
is usual for the transceivers to detect and correct it.
I know many separate transceivers with an LED polarity indicator,
the only reason for having one is for marketing value.
(Or for network installers to check the polarity with.)
As far as I know, all UTP ethernet either don't care or detect
and correct polarity.
-- glen
Posted by Phil Partridge on September 20, 2005, 9:46 am
>-- glen
Only the Orange and Green pairs are used for 10/100 Ethernet, so you do
not even need the blue or brown to be punched down for it to work.
That does NOT mean it is correct if they are not!
And, to the pedants, I do know about 100VG which uses all the pairs, but
it is *almost* extinct.
Phil Partridge
philp@pebbleGRIT.demon.co.uk
Remove the grit to reply
Posted by glen herrmannsfeldt on June 25, 2006, 5:42 am
Phil Partridge wrote:
(snip)
The polarity in question is for a given pair. That is, exchanging
orange and orange/white for example. Transceivers detect and correct
for it.
-- glen
Posted by Robert Redelmeier on May 10, 2005, 4:35 pm
> I went to new customer's office yesterday to identify and
> label the data cabling installed (but never used) by the
> previous occupant. EVERY cable was miswired, with ALL
> pairs reversed at the patch panel.
Electrons are color blind, but they do know who their dance
(twist) partners are. TIA-568A & B are side-to-side symmetrical,
so it will work just fine because no pairs are split.
I'm a little surprised because Cat5+ jacks have color codes
on them.
-- Robert
Posted by Dmitri(Cabling-Design.com on May 10, 2005, 4:51 pm
Michael Quinlan wrote:
> I went to new customer's office yesterday to identify and label the
> data cabling installed (but never used) by the previous occupant.
> EVERY cable was miswired, with ALL pairs reversed at the patch panel.
> The problem was easy enough to identify and correct, however, I'm
> baffeled by the fact that the (5) PCs they had already connected using
> the installed cabling were working! Out of curiosity, I check some
> (but not all) of the patch cables they were using, and they were all
> passed a wiremap test.
> I know that current hardware will detect and compensate for
> straight-through and cross-over wiring, but I've never heard of
> auto-correcting for reversed pairs.
> Anyone got an explaination for this one!?
It is a balanced (symmetrical) signal. The hardware sees reversed signal
exactly like normal. It would not be a good idea to do for an un-balanced
application like RS-232, but those are EXTEMELY rare these days. Well,
maybe video without a balun would be another possible un-balanced
application, but I presume they do not send video over those cables either.
But I agree, sloppy work indeed.
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling - 1984 messages and counting!
Similar ThreadsPosted
Miswired Cable Works? May 10, 2005, 8:17 am
OTDR: Launch Cable; Receive Cable April 10, 2008, 2:46 pm
Can I use a CAT5 cable as a TV Coax cable? October 14, 2006, 2:13 pm
Which end is bad of cable July 7, 2005, 10:51 pm
Cable Managers - 1U vs 2U August 12, 2004, 11:01 pm
Re Cable Managers - 1U vs 2U August 13, 2004, 10:28 am
What is the best way to strip Cat 5 cable November 27, 2004, 12:17 pm
Question about Cat 7 cable February 1, 2005, 2:03 pm
How long can a cable be February 21, 2005, 7:31 am
Cable labeler? April 22, 2005, 11:32 am
ISDN cable July 20, 2005, 11:29 am
Cable tester July 21, 2005, 12:07 am
Decent Cat 5/6 cable? July 21, 2005, 12:30 pm
cable picture November 29, 2005, 4:11 pm
