LAN and Telecom Cabling Measuring wheel
Subject Author Date
Measuring wheel Dmitri(Cabling-Design.com 10-19-04
  ---> Re: Measuring wheel Dmitri(Cabling-...10-20-04
Posted by Dmitri(Cabling-Design.com on October 19, 2004, 5:08 pm
OK, my 12 years old measuring wheel started to skip turns, so I guess it's
got to go. Has anyone come across any particular model that worked better
for him than the others? I guess digital would not hurt these days, with
memory and other perks. Have they started to make non-contact ones yet? I
mean, ones like optical mouse that you don't have to actually wheel on the
surface?
Any real-world feedback anyone?
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling - 4731 messages and counting!
Posted by Justin Time on October 20, 2004, 8:39 am
info_at_cabling-design_dot_com@foo.com (Dmitri(Cabling-Design.com)) wrote in
> surface?
Some of the contractors I work with have started to use laser
rangefinders. Works well in buildings where you can bounce off a
wall, not so well in OSP unless you run from building to building or
have a handy pole to measure to.
Posted by Dmitri(Cabling-Design.com on October 20, 2004, 5:17 pm
Thank you for response, JT
I use an ultrasonic distance measurer as a supplement for the wheel to
measure short distances ('till 50'). Works OK, especially if you measure
it twice every time to avoid possible reflection from a wrong surface. I
have to measure in buildings full of people most of the time (those under
construction normally have nice to-scale drawings), so I don't think I can
use laser rangefinders for a fear to hit someone with too bright of a
light, especially a kid in a school. So, a good old wheel is required, and
it would be nice to teach the old wheel some new tricks ;-)
comp.dcom.cabling - 4738 messages and counting!
Posted by Justin Time on October 21, 2004, 10:16 am
One company I was with had one of those really cheap wheels - one with
the little rubber bumps on the side that were supposed to toggle the
counter. If you pushed the wheel too fast, or you hit a bump or tried
to do anything with ground that wasn't paved it invariably missed
counts.
I guess the easier solution to your problem would be to look for the
model you want and then try to pick one up used (not abused.) One
source a lot of people overlook are the pawn shops. Talk to a pawn
shop that handles a lot of construction tools and if they don't have
one, they may be able to locate you one fairly quickly - and at a
reasonable price. The best thing is you can inspect the wheel before
you put money out - unlike the on-line auctions.
Rodgers Platt
Similar ThreadsPosted
Measuring wheel October 19, 2004, 5:08 pm
crudely detecting/measuring digital video March 29, 2005, 12:18 pm
