LAN and Telecom Cabling MDF cross connection block test clips
Subject Author Date
MDF cross connection block test clips James Knott 07-21-05
Posted by Jgolan on July 29, 2005, 5:07 pm
James,
I think I have seen these blocks in a fashion that they have a blue and
white checkerboard pattern for counting the pins. I don't recall if a
"pair" of pins was one above the other, like a 66 type, or were side by
side. In any case you should be able to make up a test cord using
something like a Panduit Female disconnect lug. Try searching for this
Panduit part number to see it: DNF18-187-C. These lugs are used typically
for connecting wires to circuit boards or small batteries like in a
security system.
My only other suggestion is to contact the manufacturer of the block to
see if they have something available.
James Knott wrote:
> Justin wrote:
>> hmmm...well the only thing I can think they would be are 66 blocks
>> or
>> binding post (twist on) type. Those I'm not very familiar with
>> other
>> than knowing they exist.
> These are fairly large blocks, with 100 pairs of punch down terminals
> on the
> front and either wire wrap or connectors for the equipment cables on
> the
> back. You'll generally find them only in central offices, where high
> pair
> density is desired. On larger frames, they'll be arranged vertically
> on
> one side of the frame and horizonally on the other. Smaller frames
> will
> usually have only the vertical blocks on one side. When mounted on the
> frame, they fit right next to one another. They also have a hinged
> cover.
> The cross connect wires come out of the side, and travel through rings
> attached to the frame. The rings are installed on the back or
> horizontal
> side of the frame.
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling - 2220 messages and counting!
Posted by Dmitri(Cabling-Design.com on July 26, 2005, 5:01 am
James Knott wrote:
> Does anyone know of test clips for the 100 pair MDF type cross
> connection
> blocks? I've seen some for type 66 blocks, but I'm not sure if they'd
> be
> suitable.
Regular 110 or disconnect 110? Seriously doubt about regular, but for
110-type disconnects AT&T used to have test clip that you could plug into
the same slot you took your disconnect divider from. The clips were single
pair, but with a little bit of craftiness ;-) you could put 25 of them
together. Just joking, you obviously test each pair separately 'cause it's
hard to get any useable result for 25 pairs at once without a specialized
circuit testing gizmo
OTOH, they made single-pair and 25-pair disconnect blocks, so maybe
somewhere in that Western Electric structure there could have existed such
gizmo that tested 25 pairs at once. I'm still struggling to understand why
you would need such test other than for initial post-installation backbone
test.
BTW, if you were looking for a regular 110-block clip, make sure you
realize that you cannot plug anything OVER existing cross-connect wire
(110 IDC allows only one connection), so you still can only test an empty
block/cable that's not in service.
Dmitri Abaimov, RCDD
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
comp.dcom.cabling - 2192 messages and counting!
Similar ThreadsPosted
MDF cross connection block test clips July 21, 2005, 7:39 pm
We could supply Krone module,MDF block,wiring block,STB module,Etc June 8, 2005, 9:55 am
66 block - What did I do wrong? February 9, 2006, 9:56 pm
What is the part number for the 110 equiv of a 66 block? June 25, 2007, 1:49 pm
Newbie: Punch down block 66 vs 110, how do these work? March 18, 2008, 9:20 pm
RG6 Quad clips August 18, 2007, 12:30 pm
RJ45 to 110 Cross-Connects August 24, 2004, 1:13 am
Cross Battery and Verizon? December 15, 2004, 5:01 pm
Ethernet Cross-Connects for Voice September 24, 2004, 5:22 pm
Weird Test January 30, 2005, 10:03 am
Test-um Validator February 13, 2006, 12:10 pm
Test-Um Validator April 23, 2006, 5:09 pm
test-um Validator Nt950 November 11, 2004, 9:28 am
Cabling test Failure January 19, 2006, 9:38 am
Weird Cable Test Results April 13, 2007, 7:38 pm
