LAN and Telecom Cabling Leviton T568A scheme
Subject Author Date
Leviton T568A scheme jeremy_ho 11-17-05
Posted by on November 17, 2005, 10:43 am
I have a leviton SMC panel which the insturctions says to use T568A.
So that means my wall outlet jacks will be wired up using the T568A
scheme.
I am also making my own patch cables, for both at the SMC and from wall
jack to computers. if I make the cables with T568B standard (straight
through) will it cause signal to be degraded at all?
Posted by James Knott on November 17, 2005, 8:49 pm
> scheme.
As long as you maintain proper pairing within a cable, it doesn't matter
what scheme you use. However, if you mix 568A & 568B in the same cable,
you'll wind up with a crossover.
Similar ThreadsPosted
Leviton T568A scheme November 17, 2005, 10:43 am
T568A or T568B? Check out what Fluke has to say January 13, 2005, 2:54 am
Leviton Gigamax 5e vs 5e+ November 21, 2005, 8:12 pm
Leviton routers too slow? October 20, 2004, 8:59 am
eBay: 175 Leviton Cat-5e jacks November 27, 2007, 12:17 pm
Home phone cabling -- Leviton alternatives October 24, 2004, 6:23 pm
installing cat6 via leviton structured media center September 17, 2007, 11:57 am
Instruction for Leviton 1x9 Bridged Telephone Distribution Module installation January 18, 2007, 11:47 pm
