Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by dg on September 28, 2004, 7:25 pm
Please log in for more thread options familiar with LC connectors/technology. I have pulled and terminated many, many ST MM cables using anaerobic glue on connectors at my work but have never even seen an LC cable end. Even though I only need two pairs of fiber for this run, I want to terminate them myself rather than buy pre terminated cables. Can anybody recommend a low cost termination kit for LC ends? A source to buy it? Connectors? I really appreciate any assistance you can provide. THANKS! --Dan | ||||||||||||||||
Posted by Dmitri(Cabling-Design.com on September 29, 2004, 3:42 am
Please log in for more thread options > Even though I only need two pairs of fiber for this run, I want to
> terminate > them myself rather than buy pre terminated cables. Can anybody > recommend a > low cost termination kit for LC ends? A source to buy it? Connectors? > I > really appreciate any assistance you can provide. > THANKS!
> --Dan The polishing procedure is a bit different for the LC connector in that it's a dome tip connector with a rather small dome radius that's not easy to control in the field. I've been doing those couple years back, and the procedure (by Lucent) was rather cumbersome as you needed five (!) separate sheets of Mylar film to serve as the backing on top of the polishing glass. You also needed to make less figure-8s as the surface is extremely small and is very easy to over-polish. The polishing fixture, microscope and the oven holders are different for LCs as the ferrule diameter is only 1.25mm versus 2.5mm for ST and SC. The manufacturers normally sell all the tools that are different for LC as "LC upgrade kits". Those can easily run couple hundred dollars, so if you only want to make a few terminations, it may not be easily justifiable. It is a great connector though; the insertion loss readings are usually (much) better than that of 2.5mm ferrule connectors. Note that some people have fingers too big to handle LCs conveniently (no kidding). I was teaching a fiber class few years ago, and one of the students had to connect/disconnect LCs in pairs as he just could not squeeze only one connector's latch - they were too close together for his fingers. Rather large gentleman though, it was never a problem for me personally ;-) Good luck! -- Dmitri Abaimov, RCDD http://www.cabling-design.com Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros http://www.cabling-design.com/homecabling Residential Cabling Guide ------------------------------------- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.cabling - 4616 messages and counting! ##-----------------------------------------------## | ||||||||||||||||
Posted by dg on September 29, 2004, 8:43 pm
Please log in for more thread options I usually don't mind buying tools even if they outweigh paying somebody else
to do the job. But the more I think about it, the more I think I may be able to get away with using pre terminated fiber. Still have to think about this one. Thanks for your input! Thanks, --Dan > The polishing procedure is a bit different for the LC connector in that
> it's a dome tip connector with a rather small dome radius that's not easy > to control in the field. I've been doing those couple years back, and the > procedure (by Lucent) was rather cumbersome as you needed five (!) > separate sheets of Mylar film to serve as the backing on top of the > polishing glass. You also needed to make less figure-8s as the surface is > extremely small and is very easy to over-polish. > > The polishing fixture, microscope and the oven holders are different for > LCs as the ferrule diameter is only 1.25mm versus 2.5mm for ST and SC. The > manufacturers normally sell all the tools that are different for LC as "LC > upgrade kits". Those can easily run couple hundred dollars, so if you only > want to make a few terminations, it may not be easily justifiable. > > It is a great connector though; the insertion loss readings are usually > (much) better than that of 2.5mm ferrule connectors. | ||||||||||||||||
Posted by Dmitri(Cabling-Design.com on September 29, 2004, 11:52 pm
> else > to do the job. But the more I think about it, the more I think I may > be > able to get away with using pre terminated fiber. > Still have to think about this one. Thanks for your input!
> Thanks,
> --Dan I agree with your assertion: since the LCs are smaller than your "regular" standard connectors, you may have better luck fishing the connectorized end through the tight spaces. My personal experience with preterminated fiber cables has been rather disappointing, but that may have little to do with your actual situation. -- Dmitri Abaimov, RCDD http://www.cabling-design.com Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros http://www.cabling-design.com/homecabling Residential Cabling Guide ------------------------------------- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.cabling - 4625 messages and counting! ##-----------------------------------------------## | ||||||||||||||||
| Similar Threads | Posted |
| LC Dual mode fiber cables, I need some help/info | September 28, 2004, 7:25 pm |
| Looking for 2 MM LC-LC fiber cables 30m to 50m in length-surplus/cheap | October 6, 2004, 1:48 am |
| Available USB Cables | February 13, 2007, 3:32 pm |
| V.35 cables anyone? | January 17, 2008, 12:49 am |
| tracing cables | May 9, 2006, 4:54 pm |
| Any way to organize cables that weren't labeled? | February 23, 2006, 11:32 am |
| Serial Cables - which cable should I use? | February 26, 2006, 6:31 pm |
| Short Patch Cables | March 3, 2006, 4:08 pm |
| Patch Vs. Crossover Cables | March 9, 2006, 11:18 am |
| Organising network cables | May 4, 2006, 3:38 am |
| How to keep cat5e cables from picking up RFI? | December 2, 2008, 1:24 pm |
| wire question on Cat5 or Cat5e cables | February 13, 2005, 8:12 pm |
| Brand Names for CAT6 Patch Cables | July 22, 2006, 9:37 pm |
| mission critical home made cables | August 23, 2007, 12:12 pm |
| RJ45 Cat5e cables - male one one end, female (keystone) on other | July 21, 2005, 3:48 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> not
> many,
> have
