Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by J. Clarke on February 7, 2006, 12:47 am
Please log in for more thread options phiendar@yahoo.com wrote: One should check local statutes as well. In Connecticut for example you need to either be a phone/cable company employee or have any of several classes of electrician's license, all of which require thousands of hours of documented experience, to do network cabling--it's a ludicrous requirement as the people with the licences generally do about as good a job as a drunken chimpanzee, but it's the law. Also the local codes need to be checked. One fellow of my acquaintance had to redo a major cabling job because he didn't use the one brand of cable that was authorized in a county in which the manufacturer of said cable was the major employer. > Good luck!
-- --John to email, dial "usenet" and validate (was jclarke at eye bee em dot net) | |||||||||||||
| Similar Threads | Posted |
| LAN cabling : The right time for beginning | February 1, 2006, 5:24 am |
| FA: Schlumberger SI7780 Optical Time Domain Reflectometer | March 3, 2008, 4:47 pm |
| Ethernet cabling used outside | July 29, 2004, 7:57 pm |
| LSZH Cabling | August 3, 2004, 10:11 pm |
| Help with telephone cabling | September 26, 2004, 4:10 pm |
| cabling jammed together | October 12, 2004, 10:50 pm |
| Cabling length | December 1, 2005, 4:47 am |
| Cabling Forums | February 13, 2006, 9:58 am |
| cabling labels | April 15, 2006, 4:50 pm |
| Need some pointers on my first cabling job | March 25, 2008, 7:39 am |
| cabling for colorblind people? | July 9, 2004, 11:10 pm |
| Data Communications Cabling FAQ | October 29, 2004, 7:24 am |
| Data Communications Cabling FAQ | July 29, 2004, 7:17 am |
| newbie cabling question | August 24, 2004, 3:17 pm |
| Data Communications Cabling FAQ | August 29, 2004, 7:28 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> but BEFORE the drywallers. First thing I'd do is work with the General
> Contractor to find out who the Electrical Contractor is, and to work
> with both of them on a schedule. The larger jobs I've done entailed us
> "following" the electricians from space to space. For example, most of
> the time they will start at one end of a floor of a building, and work
> towards the other. As they go, you follow. I tried to stay about 2 days
> behind them.
> You may need a low-voltage wiring permit, depending on your location,
> and you will probably be inspected on either your permit, or the
> electrical permit, before the drywall's up. Again, work this out with
> the General and the Electrical contractors. Most inspectors are going
> to freak at doing a closed-wall inspection in new construction, and you
> don't want the job red-tagged because you screwed this up. Life is much
> easier if you just dovetail your work, and your inspection, with the
> electrical guys.
> I always bidded out this work at a cheaper rate than when I was doing
> closed-wall because it's much less labor intensive. If you bid this out
> full-rate, good for you! There should be lots of gravy :)
