LAN and Telecom Cabling Keystone Jacks
Subject Author Date
Keystone Jacks Watson A.Name - \"Watt Sun, th 11-03-05
|--> Re: Keystone Jacks Robert Redelmei...11-03-05
Posted by Watson A.Name - \"Watt Sun, th on November 3, 2005, 2:46 pm
I got a ticket to install a half dozen drops in a student computer lab,
under some raised floor. The lab jockies there had already pulled
several cables under the floor, and crimped RJs on the hub end and
punched down keystone jacks on the PC ends. They showed me the job, and
I just shook my head. The fools had used cat3 telephone cable for all
of the drops. Duh.
Anyway, I removed those dud cables so I had a half dozen cat5 keystone
jacks left over to use. So I got some AMP 110Connect series faceplates
and tried one of the keystones in a faceplate, but it just fell out.
Apparently, even tho they look the same, there's a big diff in the size
of the edges where things click onto. So I punched down the jacks and
left them for later when I get a proper faceplate.
So one the way home I stopped off at the Big Orange Box hardware store
and checked out the jacks they had in the electrical dept. I found a
line of Leviton jacks and faceplates that look identical to the AMP and
keystone jacks. But they could conform the AMP size, which means that
the jacks would fall out of the Levitons as well. Or the faceplates may
be the same size as the keystone jacks which would work just fine. Does
anyone know if the Levitons are keystone compatible? Thanks.
BTW, I certified these runs with my Fluke DSP-2000, and they all passed,
but with some of the narrowest NEXt margins I've ever seen. Some of
them passed with 2.2dB or 1.6dB margins, which is a lot poorer than I
usually get. I usually test Lucent/Avaya/Systimax jacks, and they
usually do 8 or better. I'm wondering if these cheap generic keystone
jacks are the cause of this marginal performance. The cable is cat5
plenum, and the patch panel is Lucent from 1995, which is usually a good
brand. The runs were only 50 some feet. Just curious. Thanks for any
help.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Posted by Robert Redelmeier on November 3, 2005, 1:53 pm
Didja try it on those Cat3 cables?
> all passed, but with some of the narrowest NEXt margins I've
> ever seen. Some of them passed with 2.2dB or 1.6dB margins,
> which is a lot poorer than I usually get. I usually test
> Lucent/Avaya/Systimax jacks, and they usually do 8 or better.
> I'm wondering if these cheap generic keystone jacks are
> usually a good brand. The runs were only 50 some feet.
I'd be more suspicious of that old Lucent. Is it marked Cat5?
In 1995, NEXT wasn't much on the radar. Those old punchdowns
are more likely Cat3 and their PCB trace routing "untwisted".
-- Robert
Posted by Spam Catcher on November 5, 2005, 6:23 am
> Does
Yes, Leviton QuickPorts are in actuality Keystone jacks.
Stan Kee (spamhoneypot@rogers.com)
Similar ThreadsPosted
Keystone Jacks November 3, 2005, 2:46 pm
no link light...cat5 and keystone jacks connected wrong? October 25, 2004, 1:17 am
S-Video to Twisted Pair keystone adapters March 19, 2007, 11:10 pm
RJ45 Cat5e cables - male one one end, female (keystone) on other July 21, 2005, 3:48 pm
Love those ICC jacks :-) November 28, 2004, 5:21 pm
Help with NORDX jacks April 20, 2005, 8:07 am
CAT5e Jacks February 3, 2006, 8:44 am
Termination coaster for ICC jacks December 29, 2004, 6:59 pm
toolless cat5e jacks April 8, 2006, 1:50 am
eBay: 175 Leviton Cat-5e jacks November 27, 2007, 12:17 pm
straight-through T-adapter with 3 jacks for RS422 December 12, 2004, 11:44 pm
Wall mount network jacks October 6, 2005, 10:55 am
Greenlee 683 Spool Jacks - They've gotta go! January 19, 2006, 12:59 am
Did I mention how much I hate Panduit jacks? January 27, 2007, 10:16 am
Insertion rating of various brands of CAT6 jacks? March 4, 2007, 12:47 pm
