LAN and Telecom Cabling Installing S-n-S connectors on quad shield
Subject Author Date
Installing S-n-S connectors on quad shield Svensontini 08-30-07
Posted by Svensontini on August 30, 2007, 7:53 am
Hi Guys,
I bought some compspec quadshield to upgrade the ancient coax in my
house. I also bought some T&B purple connectors and a coax stripper.
Last night I gave this a shot - I adjust the coax stripper to cut just
through the outer coating and leave the wire braid intact and then
folded it back.
Now the trouble started . . . WOW! What a struggle to get the coax
shoved up into the connector!
I just did a net search and a couple places say when you use quad
shield to adjust the cutter to cut through the outer jacket, outer
wire braid and outer foil, which would just leave another layer of
wire braid and foil.
I would see where that would make things easier, but is that the
proper way?
If not, any tips on exactly how to fight that darn connector down onto
the connector?
Thanks!
-Bob-
Posted by Svensontini on September 1, 2007, 1:53 pm
Got an answer . . . the proper way is to remove the outer pvc jacket
and the outer wire braid and foil, which leaves another wire braid and
foil before the center insulator and wire. Just fold back the 2nd
layer of braid and the connector goes right on!
-Bob-
Posted by Ed Nielsen on September 2, 2007, 9:22 am
Yes, that is the correct way.
> -Bob-
Similar ThreadsPosted
Installing S-n-S connectors on quad shield August 30, 2007, 7:53 am
What's the right way to terminate RG6 Quad with F-Conn compression connectors? January 20, 2005, 12:26 am
Ethernet cable shield November 23, 2004, 5:02 pm
installing cat6 via leviton structured media center September 17, 2007, 11:57 am
RG6 Quad clips August 18, 2007, 12:30 pm
How to weatherproof RG6 Quad connections January 18, 2005, 2:25 am
FS: AMP Lightcrimp Plus Termination Kit w/new SC connectors August 3, 2005, 3:22 pm
RJ45 connectors with a larger "gate"? September 22, 2004, 10:22 pm
RJ45 connectors with a larger "gate"? September 23, 2004, 9:59 pm
Corrosion in RJ11 / RJ45 Connectors April 14, 2005, 5:51 am
How to crimp RCA connectors onto RG59 coax July 11, 2006, 4:12 pm
CAT6 Requires Shielded Connectors? August 19, 2006, 1:26 am
Transmit / Receive Assignments on fibe duplex connectors December 29, 2004, 1:28 am
