Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Peter Grandi on March 8, 2007, 4:00 pm
Please log in for more thread options >>> On Thu, 08 Mar 2007 17:08:05 GMT, CablingGuy
[ ... insertion life of RJ45 wall sockets ... ] >> 750 insertions is actually the least number that I've seen in
>> the specs in the longest time. I don't think it's overly >> optimistic. I still think that as someone said that is in lab conditions. Unfortunately my experiences in the past 10-15 years have been in places where installers have not done a great job and sometimes public areas have been involved. But even sw developer teams or sys/net adm prep teams move/change/remove PCs and their net connections frequently, and not that carefully either... >> In fact, RJ connectors of cable certifying tools' cords get
>> well in excess of 2000 re-matings easily in the course of >> testing a large enough site and I've seen them perform OK >> (but not great) after such abuse. Ahh, but I have found for example that good quality switch sockets are pretty hard wearing too. Here I am thinking specifically bulk wall sockets. > Correct, the 750 insertions is the minimum requirements from
> the connector standard. That's probably why all those spec sheets say "> 750 insertions",
they have to :-).
>> The actual number depends on thickness of gold plating layer
>> and brand name ones definitely get better gold plating. > Correct
Interesting, that's definitely one thing to look for. But I have noticed that sometimes there are _mechanical_ problems, e.g. contacts inside, where wiggling/pushing a bit on the cable makes the socket work, at least while pushed/wiggled. Never mind the case I found recently of poorly installed sockets where the incoming CAT6 was sharply bent as the wallbox was too small for a smooth turn (I think CAT6 minimum radius is 50mm or so). | |||||||||||||||||||
| Similar Threads | Posted |
| Insertion rating of various brands of CAT6 jacks? | March 4, 2007, 12:47 pm |
| Re: RG-6 QS, top brands? | April 18, 2007, 10:59 pm |
| F-CONN BNC cable insertion? | September 14, 2004, 12:19 am |
| Instrument for testing Cat6 | September 23, 2005, 11:08 pm |
| CAT6 HOME WIRING | June 25, 2007, 1:31 pm |
| Concerns over Cat6 install | November 19, 2007, 5:21 am |
| Labor premium for CAT6 vs. CAT5e | November 29, 2004, 2:28 pm |
| CAT6 Requires Shielded Connectors? | August 19, 2006, 1:26 am |
| Cat6 Patch Panel in Wall Enclosure | August 9, 2005, 8:34 pm |
| Brand Names for CAT6 Patch Cables | July 22, 2006, 9:37 pm |
| installing cat6 via leviton structured media center | September 17, 2007, 11:57 am |
| Data (Cat6) and telephone (Cat5e) lines on the same patch panel | April 26, 2007, 12:31 am |
| Love those ICC jacks :-) | November 28, 2004, 5:21 pm |
| Help with NORDX jacks | April 20, 2005, 8:07 am |
| Keystone Jacks | November 3, 2005, 2:46 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
