Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by DecaturTxCowboy on August 17, 2006, 7:46 am
Please log in for more thread options glen herrmannsfeldt wrote: They did, my bad. (1,2) and (3,6) is correct. | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by Robert Redelmeier on August 17, 2006, 9:07 am
Please log in for more thread options > Hi, I have network cable thru newly fnished house, the wiring is
> done from mechanical room into 6 different rooms. I am planning > to crimp RJ-45 connectors on each end but have the problem because > I don't know whch scheme to use. The problem is that in some > rooms I have 4-pair (8 wires) but in some rooms I have 3-pair > (6 wires) cables. What scheme should I use for RJ-45 connectors > in both cases in order to have all 6 rooms fully functional. > Website links, pictures, ideas is all welcome! The best way to do this is to terminate cables at the head end onto a patch panel. Crimping plugs onto solid is strictly temporary, and will create intermittants with flexing. In either case, for residential use I'd follow TIA-570 and go with T-568A (even though -B is more common in commercial use) in order to have the second POTS line where it's expected (orange pair). -- Robert | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by djenka2 on August 17, 2006, 9:51 pm
I've just found that only 4 wires are used for Network/Ethernet, to be exact, pins 1, 2, 3 and 6. And in 5 rooms I have 8 wires only in living area I have 6 wires, I think I am OK. Thanks anyway! Robert Redelmeier wrote: > > Hi, I have network cable thru newly fnished house, the wiring is
> > done from mechanical room into 6 different rooms. I am planning > > to crimp RJ-45 connectors on each end but have the problem because > > I don't know whch scheme to use. The problem is that in some > > rooms I have 4-pair (8 wires) but in some rooms I have 3-pair > > (6 wires) cables. What scheme should I use for RJ-45 connectors > > in both cases in order to have all 6 rooms fully functional. > > Website links, pictures, ideas is all welcome! >
> The best way to do this is to terminate cables at the head > end onto a patch panel. Crimping plugs onto solid is strictly > temporary, and will create intermittants with flexing. > > In either case, for residential use I'd follow TIA-570 and go with > T-568A (even though -B is more common in commercial use) in order > to have the second POTS line where it's expected (orange pair). > > -- Robert | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by DecaturTxCowboy on August 17, 2006, 11:56 pm
djenka2 wrote: > I've just found that only 4 wires are used for Network/Ethernet, to be
> exact, pins 1, 2, 3 and 6. > And in 5 rooms I have 8 wires only in living area I have 6 wires, I > think I am OK. > > Thanks anyway! The 3-pair cable most not likely 100 Mbps CAT5 rated, should work for 10 Mbps though. Compare the number of twists per inch to a CAT5 cable. | ||||||||||||||||||||||||||||||||||||||||||||||
Posted by glen herrmannsfeldt on August 18, 2006, 12:25 am
DecaturTxCowboy wrote: (snip) > The 3-pair cable most not likely 100 Mbps CAT5 rated, should work for 10
> Mbps though. Compare the number of twists per inch to a CAT5 cable. It isn't so much the twists per inch, but that the four pairs need to be sufficiently different. For short enough distances, it will probably work for 100baseTX anyway. -- glen | ||||||||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| How to RJ-45 with 3 pair (6 wires) cable | August 16, 2006, 8:46 pm |
| EMI Sensitivity of Coax and Twisted Pair wires | June 26, 2006, 6:16 am |
| what are the extra cable wires for | May 25, 2005, 9:16 pm |
| terminating 25 pair cable | July 18, 2004, 12:08 am |
| Is cat. 5e cable available in 50 pair, 100pair ? | November 4, 2004, 9:25 am |
| Which pair should i choose.? | February 7, 2006, 3:42 am |
| Fiber to 50-pair conversion | April 20, 2005, 5:24 pm |
| Standards for pair colours? | November 9, 2005, 6:39 pm |
| CAT5 25 pair and 66M or 110 blocks | December 26, 2005, 10:24 pm |
| 50 pair Cat 5e Outdoor line | April 21, 2006, 11:27 am |
| Video via nonshielded pair | August 8, 2006, 11:34 am |
| best RJ45 crimper under $100? | August 14, 2005, 3:27 pm |
| 1 RJ45 to 4 BT converter? | August 31, 2005, 3:18 pm |
| S-Video to Twisted Pair keystone adapters | March 19, 2007, 11:10 pm |
| RJ45 connector question | July 8, 2004, 2:55 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> parenthesis indicating wires of the same twisted pair.
