LAN and Telecom Cabling How to Plug a big hole?
Subject Author Date
How to Plug a big hole? Watson A.Name - \"Watt Sun, th 11-30-04
Posted by Eric on November 30, 2004, 10:01 am
Try firestop pillows. Pack them in the hole and then remove them as
needed. STI makes some.
Good Luck ,
Eric
Posted by Watson A.Name - \"Watt Sun, th on December 3, 2004, 3:18 am
> Good Luck ,
> Eric
Thanks. I guess those aren't available at the local Home Depot?
Posted by Dmitri(Cabling-Design.com on December 1, 2004, 2:31 am
Watson A.Name - "Watt Sun, th wrote:
> We have a hole between floors that must be about 3 inch by 16 inch, that
> allows the 100 pair telephone cables to pass between the electrical
> room
> on one floor to the same room on the floor above and below. This is
> just an open hole, no fire stop or anything. I would like to put
> something in it to stop the air from flowing thru to the next floor, so
> that drywall construction going on on one floor doesn't fill the other
> floors up with dust. I was thinking of getting some rags or plastic
> and
> stuffing it in there. Is there something that I can use that will work
> that's removable so that next time a cable needs to be run, it won't
> require a hammer and chisel or drill? Thanks.
I'm almost certain that anything that's ready-made is going to be fire
rated, meaning an overkill for you if you are sure you don't need it
firestopped. See if the construction workers have a piece of drywall they
throw out that covers your hole. May get messy to saw the cutouts for the
cables, but it will be a (semi) permanent solution. A piece of Styrofoam
board, correctly sized, might do well as a temporary plug.
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling - 819 messages and counting!
Posted by Watson A.Name - \"Watt Sun, th on December 3, 2004, 3:16 am
that
> > room
so
other
> > and
work
they
the
Styrofoam
Thanks. It probably should be firestopped since it's between floors.
But the hole is open and no one has tried to stop it up. The drywall
would have to lay on the floor, and I'm afraid that people standing in
front of the backboard will step on it and turn it to powder - which is
what I'm trying to prevent. The styrofoam might work if I could carve
it out to fit the hole. Thanks.
I was thinking about when I was a kid. My dad knew this guy who used to
do outside work like fences, etc. He would dig a hole and throw a bag
of premixed cement - bag and all - into the hole, and drive the fence
post thru it. Then he would wet the whole thing down with a couple
buckets of water. Bingo, a fencepost set in concrete.
I was thinking about how to do this after I asked here, and I thought
that I might be able to put some heavy polyethylene sheeting into the
hole, and pour a few quarts of cement into it. Then imbed a ring of
heavy wire in the cement to make a handle when it dries. ;-)
Posted by jdahl2983 on December 9, 2004, 5:24 am
From underneath (place something heavy over the hole from the top like a
brick before-hand), stuff the hole with "Roxul" or "Rock Wool" Insulation.
That is the stuff that is fire resistant made from steel slag. Pack it in
dense so it is tight and held in place by friction.
Do not use Fiberglass.
Then on the top side of the hole, push the insulation down so it is about
2" below the the floor level and fill in the top with FIRE SIL Caulking so
it is flush with the floor or top of the pipe, whichever is higher.
This will seal up your drafts and fire proof it and water proof it
too.----But you can still easily remove it in the future to pull more cable.
PS if you are after the fireproofing to meet code, check with your fire
inspector for code compliance first.
Good luck
Joel
Similar ThreadsPosted
How to Plug a big hole? November 30, 2004, 4:13 am
Cat53 cable with Phone line plug built-in? April 18, 2007, 11:29 am
cable management - source for velcro straps with screw hole? July 20, 2004, 8:04 pm
Supply Telephone Accessories,Modular Adapters Couplers,Duplex Jack,Triplex Adapters,ADSL Adapters,Plug With RJ12 Jacks November 9, 2005, 11:52 pm
