LAN and Telecom Cabling How do you properly join cat5 wire
Subject Author Date
How do you properly join cat5 wire David Jensen 11-15-06
Posted by decaturtxcowboy on November 26, 2006, 11:30 am
Robert Redelmeier wrote:
>> This thread has gone pretty far considering it is a simple
>> matter to Google Cat 5e couplers.
> No, I think this thread has been _extremely_ short
> considering it is a question of violating standards.
> Something that works now vs something that works later.
> This is exactly the sort of "gotcha" that emerges in a few
> years when someone puzzles over why gigabit is slow, and a
> tech like us spends time finding the hidden splice.
> Standards have excellent reason. Violating them can also
> make sense.
With no intent to disparage anyones' contributions to the NG, I see the
replies as insight from different directions.
There's no argument that sticking a splice up in the ceiling is not
the best idea from the "best practices" standpoint, but it might be the
only solution in a few rare situations. It certainly does not violate
any formal EIA or NEC standard.
Case in point, this is exactly what I had to do last week. I had to
extend two each thirty foot CAT5 cables that had been installed before
a wall was added and it was now impossible to simply run new cable. I
terminated the existing cables with a CAT5 jack and the new extensions
with a modular plug and CLEARLY made a note on the backboard those two
cables had a splice in the ceiling.
Posted by Robert Redelmeier on November 27, 2006, 1:18 pm
> It certainly does not violate any formal EIA or NEC standard.
This is the debateable part: EIA 568 calls for structured cabling
to be up to 90m of unbroken cable. Field termination on jacks.
Head end on jacks or an interconnect block (110) further run to jacks.
Interconnect is from the 10m patchcord allowance.
A splice (or coupler) would only fit if you considered it
"an interconnect block". Since they're often 110 parts,
they might qualify.
> before a wall was added and it was now impossible to simply run
> new cable. I terminated the existing cables with a CAT5 jack and
> the new extensions with a modular plug
I don't like jacks/plugs. Nests of crosstalk made for quick
connect/disconnect. Not reliable enough to be buried anywhere.
In the few occasions I've spliced, I use a C4 on a bit of broken
110 seat. Then loop and Tye-Rap (ouch!) for strain handling.
> and CLEARLY made a note on the backboard those two cables
Never though of writing on the back board. I labeled the
cable on both ends with orange tape marked "SPLICED".
-- Robert
Posted by DLR on November 28, 2006, 12:41 pm
That's cheating. It's more fun to figure out these things by crawling
through 1" of dust in an old closet tracing wires.
Posted by Carl Navarro on November 26, 2006, 12:34 pm
On Sun, 26 Nov 2006 16:05:28 GMT, Robert Redelmeier
I didn't see splice in the thread.
It's a coupler. Standards say that you NEVER splice a Cat5 cable.
I would have used the plan where you terminate the cable on jacks and
use a patch cord if I couldn't replace the run.
In practice, I have never spliced a data in 10 years or so of running
Cat5 cable, but I have extended data runs with visible jacks(or moved
a server or drop) lots of times.
Now voice cables are different and usually involve 709SD splices
behind a jack.
Carl
Posted by decaturtxcowboy on November 26, 2006, 3:00 pm
Right...you can't "splice" is by soldering, crimping, or scotch locking
the conductors together. I don't think he even had that in mind.
Similar ThreadsPosted
How do you properly join cat5 wire November 15, 2006, 9:41 pm
wire question on Cat5 or Cat5e cables February 13, 2005, 8:12 pm
How do I wire this terminal? February 22, 2005, 1:16 am
"Technical cable/wire" October 20, 2004, 5:39 am
wire and cable sale March 29, 2006, 8:59 pm
Crimping satin wire ? July 21, 2006, 11:00 pm
How to wire cable between network sockets January 23, 2006, 6:47 am
Web resource needed Re: Rack/Wire management January 21, 2005, 3:08 am
EMI & Cat5 March 5, 2005, 10:25 am
Two T1s on one Cat5? September 21, 2006, 10:54 am
Best Way To Bundle Cat5? January 17, 2006, 7:10 pm
Looking for retractable CAT5 July 19, 2006, 9:50 am
cat5 problem September 11, 2006, 8:45 pm
T-connections with Cat5 UTP? October 7, 2007, 4:57 pm
Average Length of Cat5 Run August 25, 2004, 10:21 am
