Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Chris on November 22, 2006, 3:49 am
Please log in for more thread options > >> Leave it to Black Box to market a non-complient standards solution
You can get them anywhere - just that I'm in the UK and that was the first
> > Why do you call it "non-complient"? It's essentially a very small > > horizontal cross-connect, which is certainly allowed. > > > > -Larry Jones > > > > Who, ME? Who?! Me?? WHO... Me?! Who, me??? -- Calvin place I came across them. Try http://www.hometech.com/techwire/tpconn.html#IC-512114 C | ||||||||||||||||||||||||||||||||||||||||
Posted by Ed Nielsen on November 22, 2006, 9:10 am
Please log in for more thread options Thanks. I just went to Blackbox's US website and didn't find it. CIAO! Ed N. Chris wrote: > You can get them anywhere - just that I'm in the UK and that was the first
> place I came across them. > Try http://www.hometech.com/techwire/tpconn.html#IC-512114 > > > C > > | ||||||||||||||||||||||||||||||||||||||||
Posted by on November 24, 2006, 9:41 am
I'm trying to figure out what's wrong with the item from Black Box? Regardless of whether you can find them on the US web site (maybe they don't carry an unshielded version), they are wonderful. I found these in the US about 3 years ago and bought 2 or 3 and then forgot where I got them. Once they were gone, when I ran across an occasion to extend a cat5 cable, I have used a 110 block to extend the cable. I was under the impression that the only concern with doing this is being sure to add a minimum of 45 feet before and after the "splice". The biggest problem is this: Who wants a 110 block (or 66 block) above the ceiling? Or for that matter, how much sense does it make to put a 110 block on a wall for one connection? Great item. I would have recommended it if I knew where to find it. MUCH BETTER solution than putting 8 pin connectors on solid wire and connecting or cross-connecting with a coupler. Just think of the number and quality of connection points in either scenario. | ||||||||||||||||||||||||||||||||||||||||
Posted by Carl Navarro on November 24, 2006, 3:59 pm
On 24 Nov 2006 06:41:30 -0800, google@swsmi.com wrote: >> > Try http://www.hometech.com/techwire/tpconn.html#IC-512114
>I'm trying to figure out what's wrong with the item from Black Box? >Regardless of whether you can find them on the US web site (maybe they >don't carry an unshielded version), they are wonderful. > >I found these in the US about 3 years ago and bought 2 or 3 and then >forgot where I got them. Once they were gone, when I ran across an >occasion to extend a cat5 cable, I have used a 110 block to extend the >cable. I was under the impression that the only concern with doing >this is being sure to add a minimum of 45 feet before and after the >"splice". This thread has gone pretty far considering it is a simple matter to Google Cat 5e couplers. Try this link http://www.nextag.com/cat5e-coupler-inline/search-html and get whatever you need. Carl Navarro | ||||||||||||||||||||||||||||||||||||||||
Posted by Robert Redelmeier on November 26, 2006, 11:05 am
> matter to Google Cat 5e couplers. No, I think this thread has been _extremely_ short considering it is a question of violating standards. Something that works now vs something that works later. This is exactly the sort of "gotcha" that emerges in a few years when someone puzzles over why gigabit is slow, and a tech like us spends time finding the hidden splice. Standards have excellent reason. Violating them can also make sense. -- Robert | ||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| How do you properly join cat5 wire | November 15, 2006, 9:41 pm |
| wire question on Cat5 or Cat5e cables | February 13, 2005, 8:12 pm |
| How do I wire this terminal? | February 22, 2005, 1:16 am |
| "Technical cable/wire" | October 20, 2004, 5:39 am |
| wire and cable sale | March 29, 2006, 8:59 pm |
| Crimping satin wire ? | July 21, 2006, 11:00 pm |
| How to wire cable between network sockets | January 23, 2006, 6:47 am |
| Web resource needed Re: Rack/Wire management | January 21, 2005, 3:08 am |
| EMI & Cat5 | March 5, 2005, 10:25 am |
| Two T1s on one Cat5? | September 21, 2006, 10:54 am |
| Best Way To Bundle Cat5? | January 17, 2006, 7:10 pm |
| Looking for retractable CAT5 | July 19, 2006, 9:50 am |
| cat5 problem | September 11, 2006, 8:45 pm |
| T-connections with Cat5 UTP? | October 7, 2007, 4:57 pm |
| Average Length of Cat5 Run | August 25, 2004, 10:21 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> CIAO!
> Ed N.
> lawrence.jones@ugs.com wrote:
