Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Al Dykes on March 12, 2006, 7:35 pm
Please log in for more thread options >>
>> That's a telephone plug that's completely unsuitable for network use. >> Do yourself a favor and go *buy* the patch cord you need, don't try to >> make it yourself. >
>This plug has 8 terminals that matches the exact dimensions to a normal cat5 >plug from what I'd measured using a precision caliper. If there is chemistry >involve that makes this unsuitable for network use then what will it be? > > The drawings in your PDF show too much untwisted wire to meet CAT5 spec. CAT 3 maybe, and it might work at 10MB. Here's a pic. There's MUCH to MUCH untwisted wire. http://www.systimax.com/pressroom/image_library/default.asp?img=39 Buy a real patch cable. -- a d y k e s @ p a n i x . c o m Don't blame me. I voted for Gore. | ||||||||||||||||||||||||||||
Posted by DecaturTxCowboy on March 12, 2006, 7:54 pm
Please log in for more thread options Sam Nickaby wrote: > This plug has 8 terminals that matches the exact dimensions to a normal cat5
> plug from what I'd measured using a precision caliper. If there is chemistry > involve that makes this unsuitable for network use then what will it be? Look REAL close at the gold plated tines. If the two or three are offset, then its for solid conductor. If the two are in line, its for stranded cable. | ||||||||||||||||||||||||||||
Posted by Carl Navarro on March 13, 2006, 7:11 am
http://support.avaya.com/edoc/docs/cib/cib28602.pdf
>> > Here's the modular plug I used >>
>This plug has 8 terminals that matches the exact dimensions to a normal cat5 >plug from what I'd measured using a precision caliper. If there is chemistry >involve that makes this unsuitable for network use then what will it be? Thank Eli Whitney for that. A 4 pin handset plug will fit in the jack, so why don't you solder that up and use it? The particular plug you refer to was designed a long time before Cat-5e was a standard. It's O.K. In fact, rather than use any kind of standard, take you 8 conductors and put them down in any color sequence you like. Just match them on the other end and check them with a "tester" for continuity. If it works, you did a good job. If it doesn't you can post to 4 usenet groups and then argue with the standards. Oh, you already did. Carl Navarro | ||||||||||||||||||||||||||||
Posted by Robert Redelmeier on March 13, 2006, 9:23 am
> This plug has 8 terminals that matches the exact dimensions > to a normal cat5 plug from what I'd measured using a precision > caliper. If there is chemistry involve that makes this unsuitable > for network use then what will it be? The network "chemistry" is balanced signalling. It is the magic that allowed clever network engineers to run 100 MHz over 100m of wild country ten+ years ago when motherboard designers could hardly get 50 MHz over 20cm on a PCB with unbalanced signals. In this case, your plug has projections that may block other ports or might not fit in the jack properly. Less obviously, it has long parallel unbalanced conductors. AKA "untwist". A crimped plug has about 1 cm of untwist. This low-tool plug has at least 3 cm. But this isn't as fatal as trying to run silver satin at 100 MHz. -- Robert | ||||||||||||||||||||||||||||
Posted by on March 13, 2006, 2:13 pm
> This plug has 8 terminals that matches the exact dimensions to a normal cat5 > plug from what I'd measured using a precision caliper. If there is chemistry > involve that makes this unsuitable for network use then what will it be? No chemistry, physics. There are *lots* of DC and AC electrical properties that are every bit as important as the physical properties for correct operation. Your plug is probably OK as far as the DC properties, but there's no way it's going to come anywhere close to meeting the AC properties required for a reliable 100BaseT connection. -Larry Jones Hmph. -- Calvin | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Homemade cat5 cable using existing phone line fails. | March 11, 2006, 5:41 am |
| Cat53 cable with Phone line plug built-in? | April 18, 2007, 11:29 am |
| Phone + Network on 1 CAT5 cable? | January 18, 2007, 10:12 am |
| Cat5 phone wall plates with post | July 1, 2005, 11:40 am |
| Firewire using on existing Ethernet cable | August 6, 2005, 7:36 am |
| Existing conduit w/fiber,copper,pull string | February 21, 2005, 10:56 pm |
| Article on Balanced Line | December 12, 2004, 7:08 pm |
| 50 pair Cat 5e Outdoor line | April 21, 2006, 11:27 am |
| lengthening CAT5 cable | September 22, 2005, 1:49 pm |
| Can I use a CAT5 cable as a TV Coax cable? | October 14, 2006, 2:13 pm |
| Cat5 568B cable wrong... but right. Huh? | December 18, 2004, 4:40 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:57 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:56 pm |
| HPNA/phone-net for MDU? | March 23, 2006, 11:23 pm |
| Troubleshooting a 100' CAT5 cable - need assistance | April 23, 2005, 10:37 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
