Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Sam Nickaby on March 11, 2006, 5:41 am
Please log in for more thread options I made my own Ethernet cable to extend our DSL connections to 25 feet. I used a cat5 male connector on each end. I use two ordinary phone line cords. After I lined them up identically like what cat5 cables are supposed to I then solder and assemble the cords. I then check the resistance on all eight terminals. They all check fine. The problem is when I plug one end of the cable to DSL modem the other to the PC the cable fails to work. I keep getting "network cable unplug" and "network cable plug" consistently until I unplug the cable. Does this mean that the cat5 won't accept the ordinary phone cables? Thanks | ||||||||||||||||||||||||||||
Posted by David Schwartz on March 11, 2006, 6:11 am
Please log in for more thread options To make a cat patch cord, you need to use cat 5 cable. DS | ||||||||||||||||||||||||||||
Posted by Peter Kolbe on March 11, 2006, 6:15 am
Pins 1 and 2 must be on one twisted pair Pins 3 and 6 must be on another twisted pair If you do not have pairs that are twisted together all the way through the cable, then you cannot use it. If they are not grouped specifically on the pairs, then there will be crosstalk, etc. Peter >I made my own Ethernet cable to extend our DSL connections to
> 25 feet. I used a cat5 male connector on each end. I use two ordinary > phone line cords. After I lined them up identically like what cat5 cables > are supposed to I then solder and assemble the cords. I then check the > | ||||||||||||||||||||||||||||
Posted by Robert Redelmeier on March 11, 2006, 10:14 am
This is usually flat silver satin. No-where close to Cat5. Strictly speaking, Cat5 describes an end-to-end link quality that should be certified. When components are marked "Cat5", it means that the mfr believes that they can be used to make a link that will pass Cat5 testing _iff_ you do everything right. > After I lined them up identically like what cat5 cables are
> supposed to I then solder and assemble the cords. I then check > the resistance on all eight terminals. They all check fine. Low resistance straight thru is not enough. Ethernet uses differential signals which must travel on balanced twisted pairs to avoid corruption. Electrons may be color blind, but they know who their dance [twist] partners are. -- Robert | ||||||||||||||||||||||||||||
Posted by Roy on March 11, 2006, 11:21 am
Sam Nickaby wrote: > I made my own Ethernet cable to extend our DSL connections to
> 25 feet. I used a cat5 male connector on each end. I use two ordinary > phone line cords. After I lined them up identically like what cat5 cables > are supposed to I then solder and assemble the cords. I then check the > resistance on all eight terminals. They all check fine. > > The problem is when I plug one end of the cable to DSL modem the other > to the PC the cable fails to work. I keep getting "network cable unplug" and > "network cable plug" consistently until I unplug the cable. Does this > mean that the cat5 won't accept the ordinary phone cables? > > Thanks > > Your cable is not CAT5 since it doesn't have the right number of twists but then again you don't need CAT5. Your DSL modem probably runs at 10Mbps which calls for CAT3 cable. CAT3 has less twists and most telco cable meets the criteria. The cable you have may be below that but it might not matter for a the short run. YMMV The link light would come on in any case so you have something else wrong. Your modem may require a cross over cable or you don't have it wired correctly (pin1 to pin1). You actually only needed two pair 1-2 and 3-6. Correct that problem and then try your cable. If you don't get errors, you are just fine Roy | ||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Homemade cat5 cable using existing phone line fails. | March 11, 2006, 5:41 am |
| Cat53 cable with Phone line plug built-in? | April 18, 2007, 11:29 am |
| Phone + Network on 1 CAT5 cable? | January 18, 2007, 10:12 am |
| Cat5 phone wall plates with post | July 1, 2005, 11:40 am |
| Firewire using on existing Ethernet cable | August 6, 2005, 7:36 am |
| Existing conduit w/fiber,copper,pull string | February 21, 2005, 10:56 pm |
| Article on Balanced Line | December 12, 2004, 7:08 pm |
| 50 pair Cat 5e Outdoor line | April 21, 2006, 11:27 am |
| lengthening CAT5 cable | September 22, 2005, 1:49 pm |
| Can I use a CAT5 cable as a TV Coax cable? | October 14, 2006, 2:13 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:57 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:56 pm |
| HPNA/phone-net for MDU? | March 23, 2006, 11:23 pm |
| Cat5 568B cable wrong... but right. Huh? | December 18, 2004, 4:40 pm |
| Troubleshooting a 100' CAT5 cable - need assistance | April 23, 2005, 10:37 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> and
> Thanks
