http://www.cablestogo.com/product.asp?cat_id=1408&sku=03787 -- Bob included. the ">
LAN and Telecom Cabling Home Wiring for DSL and 4 Extensions
Subject Author Date
Home Wiring for DSL and 4 Extensions Michael Knight 04-24-05
Posted by Bob Dozier on April 25, 2005, 1:26 pm
Oh look! http://www.cablestogo.com/product.asp?cat_id=1408&sku=03787
-- Bob
> I like this item. See #8631 at this link
> http://www.smarthome.com/865104.html
> If you don't already have a filter, see item 865170 at the same link.
> Some CAT5 module kits have a 'limited use' plastic 110 punch tool
included.
> In
> a pinch, I have used two flat screwdrivers to force the wire in and trim
the
> ends.
> Hey, a quick google search - found a $13.00 tool...
> http://shop.store.yahoo.com/tmt/nonpuntoolwi.html
> -- Bob
> > I have a DSL outside splitter near the NID.
> > I would like to have four voice extensions (one telephone number)
> installed
> > in the house.
> > After browsing the web, I've decided I want to use star topology.
> > I already have the wires connected to the room jacks and pulled to the
> > location where I want to centrally connect.
> > What should I purchase to do this? A Wall Mount 110 Block seems to be
> > over-kill. I also don't have access to a punch down tool, and they seem
> to
> > be fairly expensive.
> > Thanks in advance,
> > Mike
Similar ThreadsPosted
Home Wiring for DSL and 4 Extensions April 24, 2005, 1:13 am
New Home Wiring Questions February 1, 2006, 10:59 am
CAT6 HOME WIRING June 25, 2007, 1:31 pm
Wiring home for satellite & ethernet June 23, 2005, 11:25 pm
retrofit home with structured wiring.. June 24, 2005, 6:22 pm
Fiber to the home - What are the standards ? February 25, 2005, 8:26 pm
Fibers inside a home March 16, 2006, 7:52 am
Home Networking Advice May 9, 2007, 2:46 am
Home phone cabling -- Leviton alternatives October 24, 2004, 6:23 pm
mission critical home made cables August 23, 2007, 12:12 pm
Home Network Run Issue - Unsure next step June 15, 2007, 6:28 pm
802.11G health issue and home network cabling question September 25, 2006, 8:32 pm
Need advice for a wall-mounted patch panel for home network January 17, 2006, 10:34 am
Please provide detail instruction for home Voice & Data lines setup April 30, 2007, 1:03 pm
Wiring Manufactures July 9, 2004, 2:19 pm
