LAN and Telecom Cabling Home Networking Advice
Subject Author Date
Home Networking Advice Shawn B. 05-09-07
Posted by Shawn B. on May 9, 2007, 2:46 am
Greetings,
I've been scouring the net for what bits and pieces I can. But I want to
verify my choices.
I want to wire my house with Gig E. I will install wall jacks in 6 rooms,
each with 6 ports. 4 of the ports will be used as inputs. 1 will be a
dedicated ethernet uplink and 1 will be a dedicated RJ-11. The purpose of
the uplink and RJ-11 is so I can move my DSL into any room, plug from the
phone jack to the RJ-11, and it'll in-turn wire into the DSL modem in the
closet. The same for the ethernet uplink, so I can switch to
cable/satellite broadband and just plug it into any uplink rather than
running another wire throught the house.
Question 1: That said, in the "datacenter" closet I will install a 24-port
Gig E switch. Each of the wall ports will lead into the closet. The
cabling I should be using is solid wire I gather. Should it be plenum? or
is UTP sufficient (standard residential). There is a significant price
difference.
Question 2: The wires should terminate at a patch panel? From the patch
panel to the switch using no more than 3ft./1m patch cable, standard
twisted? Some places mention a punch-down board or something like that? Is
it necessary? Is there any reason I can't just terminate the wall cables
with standard cat6 connectors and directly plug into the switch and avoid
the patch panel all-together?
I thought about running a single wire to the walls, then using the 3COM
wall-mount 4-port switch with 2 uplinks. Look exactly like what I'd need.
But it is limited to T 10/100 and won't do Gig E. Also, it is $179 each
box. I'd need 6 of them. The price is too high so I'll do it the old
fashioned way.
Question 3: Do I run the cables directly through the walls or should I run
them through something like PVC? Do I use a plastic or a metal box that the
wall plate bolts to?
I will installing a vent into the door of the close for ventilation and will
also install a fan into the room to help keep it cool in there, can get hot
in the summer days. I might, but not sure, extend my standar A/C to vent
the closet. I plan to put my NAS boxes in there, I have a few
multi-terabyte RAID NAS devices that I'd like to move out of my computer
room.
Thanks,
Shawn
Posted by MURF on May 9, 2007, 8:18 am
Shawn B. wrote:
> Greetings,
> verify my choices.
Not sure why you'd want to move the DSL, just have it installed in the
same place as your switch, patch panel etc and patch the ethernet from
it there. Also you can use a voice adaptor in an RJ45 socket and move
it like that. Basically keep everything RJ45 - RJ45.
> difference.
Depending on where you are going to install it and how it is contained
and also what local regs apply to where you are. But solid core definitely.
Yes connect all to back of patch panel. You can use up to 5mtrs of patch
cable. I would not suggest that you direct connect solid cat6 into an
RJ45 plug, bit of a pain and also restricts you physically when you are
moving services about. Keep the patch panel is my advice.
> fashioned way.
Answered yourself here, keep it simple!
In a house, I would run em through the walls if it is new build (walls
not finished yet) or use PVC if the house is already finished. Just use
a 44mm deep PVC wall mounted back box at the outlet end, you'll need
this for the bend radius of the cat6.
> room.
The AC and vent sounds like a winner, especially if you've got that muck
kit sitting in there.
Hope this helps.
> Thanks,
> Shawn
Posted by Robert Redelmeier on May 9, 2007, 10:42 am
> in 6 rooms, each with 6 ports. 4 of the ports will be used
> as inputs. 1 will be a dedicated ethernet uplink and 1 will
> be a dedicated RJ-11. The purpose of the uplink and RJ-11 is
> so I can move my DSL into any room, plug from the phone jack
> the closet. The same for the ethernet uplink, so I can switch
> to cable/satellite broadband and just plug it into any uplink
> rather than running another wire throught the house.
I'm really not sure why you think you need all that wire!
The std would be two runs to each room. One for voice,
the other for data. At most three (voice, 100 and GigE) if you
really need GigE on the comp in the same room as DSL.
Move DSL and SoHo router into any room, plug DSL into voice
and router WAN. Plug uplink and comp into router LAN-side
if 100 will do on that comp. If not, plug comp into GigE and
router into 100. You couple probably make do with two runs by
putting 100 on the unused pairs of voice (use splitter boxes).
> install a 24-port Gig E switch. Each of the wall ports
> will lead into the closet. The cabling I should be using
> is solid wire I gather. Should it be plenum? or is UTP
> price difference.
This depends on local fire codes. For non-air duct runs
in typical N.Am stick-built construction, UTP is more than
sufficient. But some jurisdictions call for plenum anyways.
> From the patch panel to the switch using no more than
> 3ft./1m patch cable, standard twisted? Some places mention
> a punch-down board or something like that? Is it necessary?
> switch and avoid the patch panel all-together?
Crimping plugs is much more difficult than it looks.
Punching down is easier than it looks. Yes, you can skip the
patchpanel and patchcords at your peril. Even when properly
done, solid crimped plugs are unreliable with movement.
> or should I run them through something like PVC? Do I use
> a plastic or a metal box that the wall plate bolts to?
It's low voltage so you can run any which way. Avoid staping.
If you can, put in PVC conduit, especially as vertical chases
and for hard-to-reach outlets.
> ventilation and will also install a fan into the room to help
> keep it cool in there, can get hot in the summer days. I might,
> but not sure, extend my standar A/C to vent the closet. I plan
> to put my NAS boxes in there, I have a few multi-terabyte RAID
> NAS devices that I'd like to move out of my computer room.
Sounds like lots of actives. Add up your heatload. You will need
AC unless you have large (or powered) transom vents and intakes.
A room fan is unlikely to do much -- if properly installed,
the box fans will keep the room air stirred up enough (contant
temperature). It's not as if electronics sweat!
-- Robert
> Thanks, Shawn
Posted by Al Dykes on May 9, 2007, 10:59 am
>> price difference.
Plan out how many access point locations you need for full-signal WiFi
coverage and provision for power over ethernet at your wire center. A
few WiFi pulls might save you a fortune in copper pulled to places
where it will never be used.
Put APs at those locations only when you find you need network access
in a particular part of the house. Radio is only going to get faster
and faster and upgrading APs as-needed will be cheap.
With planning, APs can be hidden in closets and crawl spaces. PoE
means you don't need to have a nearby power receptacle.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore. A Proud signature since 2001
Posted by Carl Navarro on May 9, 2007, 12:21 pm
>Greetings,
>verify my choices.
>difference.
Yes there is. Your local codes will tell you whether you need plenum.
Generally in our area, you do not need plenum in any residential.
Yes. Not necessarily, but it's hard to construct a scenario where
you'd need longer than 3' patch cords. The punch-down board is on the
back of the patch panel. Yes, the reason is you wanted Cat-6. There
are barely Cat-5e plugs that you can "crimp" on a cable and doubtful
that Cat-6 modular plugs exist for field termination.
>fashioned way.
Good thinking.
It depends. I can't see into your walls and attic/basement, and I
don't have your local codes, so my advice would be worth every penny
you paid for it. I wish I had done my construction with smurf (Carlon
flexible) tubing to a common point so I could have run new Cat-5e
cables to locations I never dreamed we'd need data. The home
improvement store sells this stuff in, I think, 250 rolls (1/2 and 3/4
inch). My mounting box of choice for old work is the Caddy MPLS
single gang box with screws (www.erico.com). It's forgiving in that
you cut a hole and tighten up a band to grasp the drywall and your
hole doesn't have to be exactly level because the plate can shift
about an 1/8 of an inch either way. Here, low voltage doesn't have to
be in a box, it can be in a plaster ring. In "old work" boxes, if it
ain't level to start with, it ain't level :-).
Carl
Similar ThreadsPosted
Home Networking Advice May 9, 2007, 2:46 am
Need advice for a wall-mounted patch panel for home network January 17, 2006, 10:34 am
Cabling and Networking Websites? September 5, 2005, 1:49 pm
Powerline Networking Question March 2, 2006, 10:39 am
best suppliers for telecom/networking wiring and adapters December 12, 2004, 11:49 pm
Basic UTP tool advice November 29, 2004, 7:01 pm
Telephone wireing advice please. November 30, 2004, 5:01 am
Looking for advice on Telephone / Network System within UK September 6, 2004, 7:03 pm
seeking vga cable extension advice February 3, 2006, 9:36 am
Need telephone cable installation troubleshooting advice October 31, 2005, 4:42 am
Fiber to the home - What are the standards ? February 25, 2005, 8:26 pm
Home Wiring for DSL and 4 Extensions April 24, 2005, 1:13 am
New Home Wiring Questions February 1, 2006, 10:59 am
Fibers inside a home March 16, 2006, 7:52 am
CAT6 HOME WIRING June 25, 2007, 1:31 pm
