Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Jason on November 17, 2004, 3:55 pm
Please log in for more thread options There are 4 pairs of differential wires found in CAT5E in order to operate gigabit ethernet. Do all the differential pairs found in CAT5E cable be the same length? Can pair 1 longer than pair 2 by say 3 inches? Thanks, Jason | ||||||||||||||||||||||
Posted by Justin T. Clausen on November 17, 2004, 4:09 pm
Please log in for more thread options Jason, Technically no, this will not effect the transmission. In fact, because of the difference in twist rate between the pairs, there is a substantial length difference between the pairs. The real question is what are you needing to accomplish that the pairs are different lengths? JT | ||||||||||||||||||||||
Posted by Robert Redelmeier on November 18, 2004, 2:34 am
Please log in for more thread options > Do all the differential pairs found in CAT5E cable be the
> same length? Can pair 1 longer than pair 2 by say 3 inches? Yes. This is called "pair slew" and can be significant for things like S-video. 1000baseT has buffering to compensate. -- Robert | ||||||||||||||||||||||
Posted by Jason on November 18, 2004, 12:13 pm
Please log in for more thread options > > Do all the differential pairs found in CAT5E cable be the
> > same length? Can pair 1 longer than pair 2 by say 3 inches? >
> Yes. This is called "pair slew" and can be significant for > things like S-video. 1000baseT has buffering to compensate. > > -- Robert Thanks for your reply. What I'm trying to achieve is to make a patch panel for gigabit ethernet, where I need to use board-to-board connector on a PCB, and route the signals from a RJ45 jack to another jack, using twisted-pair ribbon cable and the cable is connected in PCB. So I'm wondering is that critical to have absolute the same length from pair 1 to 4. 1000BaseT does have buffering and error correction, so if I'm going to use it as normal Ethernet data transfer I would think that it does not quite matter that much. It seems very weird anyone in the world would ever do this, but due to a lot of constrains in our system, we'll like to try this out. Really appreciate your comment. Thanks. Jason | ||||||||||||||||||||||
Posted by Dmitri(Cabling-Design.com on November 18, 2004, 7:53 am
Please log in for more thread options Jason wrote:
> I have a critical question:
> There are 4 pairs of differential wires found in CAT5E in order to > operate gigabit ethernet. > Do all the differential pairs found in CAT5E cable be the same length?
> Can pair 1 longer than pair 2 by say 3 inches? > Thanks,
> Jason Well, let's see what we got here: #1 You can have 45ns delay skew in a 100m piece of a CAT5E cable. This is the difference between the times the signal reaches the other end on the fastest (shortest) pair and the slowest pair. So, that's 4.5E-08 seconds #2 The signal travels at the speed of light times NVP (nominal velocity of propagation), which is about 0.67 for CAT5E. Therefore the speed of the signal in a CAT5E cable is 2.01E+08 m/s #3 Multiplying it all up, we have 4.5E-08 x 2.01E+08 equals 9.045 meters allowed difference between the lengths of the shortest and the longest pairs. This is NOT the cable jacket length; the cable jacket length is less than that because the pairs are twisted. For simplicity we'll make the cable jacket length equal 5 meters. How much of a difference a 3 inch (0.0762 meter) piece can make if you are already allowed to have 5 meters difference? Not very much. HOWEVER, by saying that you are making pairs 3 inches different in length, you are saying that you have to take the outer jacket of the cable off for at least 3 inches (plus whatever you need for your terminations). This is a big no-no in cabling installation because it creates problems with pairs mixing with pairs of other cables, over-bending, un-twisting and all that bad stuff that can happen to a pair when it's not protected by an outer jacket. The signal might get killed by excessive NEXT or FEXT or any other parameter you pick before you even get to the point of calculating the difference in delays. So, with that said, if your application allows, don't make them 3 inch different in length. If it does not, make sure the pairs' twists are undisturbed, and different cables' pairs don't mix and you'll be OK. -- Dmitri Abaimov, RCDD http://www.cabling-design.com Cabling Forum, color codes, pinouts and other useful resources for premises cabling users and pros http://www.cabling-design.com/homecabling Residential Cabling Guide ------------------------------------- ##-----------------------------------------------## Article posted with Cabling-Design.com Newsgroup Archive http://www.cabling-design.com/forums no-spam read and post WWW interface to your favorite newsgroup - comp.dcom.cabling - 727 messages and counting! ##-----------------------------------------------## | ||||||||||||||||||||||
| Similar Threads | Posted |
| Gigabit Ethernet Cabling | November 17, 2004, 3:55 pm |
| Cat 5e vs 6 and gigabit ethernet | February 4, 2006, 1:12 am |
| Shielded Cat5e for Gigabit Ethernet | September 14, 2004, 9:35 pm |
| Evaluating STP Quality for Gigabit Ethernet | July 22, 2006, 9:15 pm |
| Gigabit Cabling and Auto-MDIX Problems | May 24, 2005, 1:41 am |
| Ethernet cabling used outside | July 29, 2004, 7:57 pm |
| Ok this may be a beaten up subject but...c5e vs c6 gigabit. | June 1, 2006, 10:11 am |
| DIY Ethernet | September 10, 2004, 8:57 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:57 pm |
| Cat 5 for phone and ethernet? | December 20, 2004, 9:56 pm |
| PoE and Ethernet switches | October 1, 2005, 10:22 am |
| Re: ethernet polarity | November 4, 2005, 10:44 pm |
| Ethernet cable shield | November 23, 2004, 5:02 pm |
| Ethernet STP Patch in STP installation | July 25, 2006, 9:38 am |
| Ethernet Cable Woes - On and Off every second | February 19, 2007, 8:20 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Thanks,
> Jason
