LAN and Telecom Cabling Gigabit Cabling and Auto-MDIX Problems
Subject Author Date
Gigabit Cabling and Auto-MDIX Problems Brian 05-24-05
Posted by Brian on May 24, 2005, 1:41 am
Hi, I am currently attempting to upgrade from 100BaseT, with CAT5 at
home and adding a new link with CAT7 cable, that I want to use for
Gigabit Ethernet. I Bought two Telegaertner double AMJ45 sockets. For a
first test I just cabled the two of them together straight through.
1 White/Orange
2 Orange
3 White/Green
4 Blue
5 White/Blue
6 Green
7 White Brown
8 Brown
At one end is a PC with an Intel 1000 MT Pro NIC, and the other end a
new D-Link DGS-10008D, 8 Port Gigabit switch with Auto-MDIX. SO I have a
patch cable from the switch to the first socket,then the cable run, then
a short patch cable, then the PC. The switch has 3 other PCs connected,
2 at 100BaseT and 1 with the same Intel NIC again. All connected by
short patch cables. The three PCs on the switch can communicate OK. I
get a cable fault shown by the Switch when starting for the new cable
run. I was the opinion that AUTO-MDIX would sort out any problems, at
least with any patch cables. It certainly doesn't work at all.
Here is a link to the sockets I am using.
http://www.voltus.biz/pphlogger/dlcount.php?id=voltusbiz&url=/assets/own/MA_AMJ8_8UP0_Cat6+.pdf
The datasheet with the sockets shows two ways to connect them:
B:
1 White/Orange
2 Orange
3 White/Green
4 Blue
5 White/Blue
6 Green
7 White Brown
8 Brown
and A:
1 White/Green
2 Green
3 White/Orange
4 Blue
5 White/Blue
6 Orange
7 White/Brown
8 Brown
I guess this looks like a cross over. But shouldn't the AUTO-MDIX sort
this out for me?
I would be very gratefull for any insights, I want to add a few new
sockets in the house and plan to use these sockets and this cable (its
the same price as CAT5.
Cheers Brian
Posted by Brian on May 24, 2005, 2:15 am
> 1 White/Orange
> 2 Orange
> 3 White/Green
> 4 Blue
> 5 White/Blue
> 6 Green
> 7 White Brown
> 8 Brown
> B:
> 1 White/Orange
> 2 Orange
> 3 White/Green
> 4 Blue
> 5 White/Blue
> 6 Green
> 7 White Brown
> 8 Brown
> and A:
> 1 White/Green
> 2 Green
> 3 White/Orange
> 4 Blue
> 5 White/Blue
> 6 Orange
> 7 White/Brown
> 8 Brown
> this out for me?
> Cheers Brian
Well it looks like the short patch cable to the NIC is bad. But I would
appreciate knowing how exactly I should cable between the sockets,
straight through in every case?
Cheers Brian
Posted by Dmitri(Cabling-Design.com on May 24, 2005, 2:17 am
> Cheers Brian
Yes, jack-to-jack connections should always be straight-through. If you
need any conversion done, such as cross-over of any kind, it has to be
done with an external cable (cord).
It will make sense if you think about it: what if you need another
cross-over, not 100Base-TX? You will need to re-wire the jacks, and more
of the time they'll be inside the wall. So, by leaving any non-standard
stuff outside the wall you'll do yourself a huge favor comes
re-configuration time.
BTW, here are couple links for your reference:
10/100-Base-T crossover:
http://www.cabling-design.com/references/pinouts/10-100base-t-crossover.shtml
Gigabit Ethernet crossover:
http://www.cabling-design.com/references/pinouts/1000base-t-crossover.shtml
Dmitri Abaimov, RCDD
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling - 2007 messages and counting!
Posted by Brian on May 24, 2005, 9:57 am
>>Cheers Brian
Dmitri,
OK, thanks for the reply. Yes it does make sense. Whats about the
Auto-MDIX though, shouldn't it at least sort any cross-over vs.
straight-through problems out? No doubt knowing what I am doing, and
getting it correct from the start is better than letting some automatic
feature try to sort it out for me. I assumed MDIX would at least free me
from worrying about straight-through and cross-over patch cables.
Cheers Brian
Posted by Dmitri(Cabling-Design.com on May 24, 2005, 6:43 pm
Brian wrote:
>> Dmitri,
> me
> Cheers Brian
Well, it does take care of the conversion, but on the lower-end equipment
you only have it on the uplink port, NOT on every port of the switch. On
older equipment you don't have it at all, so it is better to stick with
straight jack-to-jack connections just in case.
Good luck!
comp.dcom.cabling - 2012 messages and counting!
Similar ThreadsPosted
Gigabit Cabling and Auto-MDIX Problems May 24, 2005, 1:41 am
Gigabit Ethernet Cabling November 17, 2004, 3:55 pm
Phantom CAT5 Wiring Problems ? July 6, 2007, 12:21 pm
Cat 5e vs 6 and gigabit ethernet February 4, 2006, 1:12 am
Ok this may be a beaten up subject but...c5e vs c6 gigabit. June 1, 2006, 10:11 am
Shielded Cat5e for Gigabit Ethernet September 14, 2004, 9:35 pm
Evaluating STP Quality for Gigabit Ethernet July 22, 2006, 9:15 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
LSZH Cabling August 3, 2004, 10:11 pm
Help with telephone cabling September 26, 2004, 4:10 pm
cabling jammed together October 12, 2004, 10:50 pm
Cabling length December 1, 2005, 4:47 am
Cabling Forums February 13, 2006, 9:58 am
cabling labels April 15, 2006, 4:50 pm
Need some pointers on my first cabling job March 25, 2008, 7:39 am
