LAN and Telecom Cabling Fishing one network cable in wall?
Subject Author Date
Fishing one network cable in wall? DaveC 11-04-04
Posted by Carl Navarro on November 5, 2004, 2:57 am
>A friend in a medical office wants a network connection added. Bringing a
>cable from the hub to the ceiling above the desk is a piece of cake. Getting
>it inside the wall is ... well, I've never done this before.
>The ceiling is suspended type with removable tiles. The wall is sheet rock
>over metal studs. What is the easiest (only?) way to get a single Cat-5 cable
>to its destination in this wall, a few feet off the floor?
>Do these types of walls have fire blocking? Or other obstacles that would
>require busting through the sheet rock to run the cable?
First you start by drilling a small hole above the ceiling. You need
to find out if the wall is insulated. If it's hollow, fishing is a
piece of cake :-) Fishing line, a sinker, a chain, or any other
gravity fed device will work.
If there happens to be an existing outlet for telephones, you can
remove the cover and trace the route of that cable, it's a simple
matter to hook a cable to the existing one and pull two cables down.
If the wall is insulated, you have a bigger problem. Locate the stud.
You want to drill a hole as close to the stud as possible, because you
want to make your fishtape, green sticks, tent poles or whatever hug
the stud as it goes down the wall. It's usually easier to fish from
top to bottom, because you have a 2x4 inch hole to work with below and
you don't want to make a big exit hole at the top.
HTH
Carl Navarro
Similar ThreadsPosted
Fishing one network cable in wall? November 4, 2004, 6:01 pm
Wall mount network jacks October 6, 2005, 10:55 am
Creating a new network with cabling and wall outlets in 2 buildings June 14, 2005, 9:17 am
Need advice for a wall-mounted patch panel for home network January 17, 2006, 10:34 am
Fishing tips for finished basement without drop ceiling March 7, 2005, 2:27 pm
Wiring on RJ45 wall socket July 8, 2007, 6:22 am
Cat5 phone wall plates with post July 1, 2005, 11:40 am
Cat6 Patch Panel in Wall Enclosure August 9, 2005, 8:34 pm
Newbie question re connecting wall sockets November 10, 2006, 12:24 pm
Allen Tel hinged wall mount bracket screws September 30, 2004, 2:48 am
Blilnking network cable id-ers October 14, 2004, 11:20 pm
Leasing network cable infrastructure January 20, 2006, 2:45 pm
How to wire cable between network sockets January 23, 2006, 6:47 am
Phone + Network on 1 CAT5 cable? January 18, 2007, 10:12 am
Network in new house June 12, 2005, 6:48 pm
