LAN and Telecom Cabling Fishing one network cable in wall?
Subject Author Date
Fishing one network cable in wall? DaveC 11-04-04
Posted by DaveC on November 4, 2004, 6:01 pm
A friend in a medical office wants a network connection added. Bringing a
cable from the hub to the ceiling above the desk is a piece of cake. Getting
it inside the wall is ... well, I've never done this before.
The ceiling is suspended type with removable tiles. The wall is sheet rock
over metal studs. What is the easiest (only?) way to get a single Cat-5 cable
to its destination in this wall, a few feet off the floor?
Do these types of walls have fire blocking? Or other obstacles that would
require busting through the sheet rock to run the cable?
Thanks,
Please, no "Go Google this" replies. I wouldn't
ask a question here if I hadn't done that already.
DaveC
me@privacy.net
This is an invalid return address
Please reply in the news group
Posted by on November 4, 2004, 10:13 pm
In general, you should be able to drop a wire in from the top of the
wall (may have to cut a hole in the sheetrock above the suspended
ceiling), and cut out a box further down the wall. Usually, it's
drywall and stud construction, though the studs may be metal.
Electricians do this all the time, it's not rocket science, though
experience counts for a lot.
Posted by James Knott on November 4, 2004, 11:45 pm
> Getting it inside the wall is ... well, I've never done this before.
> cable to its destination in this wall, a few feet off the floor?
If it's standard office type construction, it's just drywall over studs.
Depending on the metal studs used, there may already be holes in it, for
feeding cables through. If not, it's not difficult to punch a hole
through. Then cut a hole in the drywall, below the hole in the top plate
and use a fish, to pull the cable through. If the desk is away from the
wall, you may want to consider a pole for bringing the cable down. There
are many types available. Another method of coming down the wall, is
conduit, that sticks to the wall, over the cable.
Lots of options, depending on the situation.
(This space intentionally left blank)
Posted by Michael Quinlan on November 5, 2004, 4:25 pm
Carl's suggestion from way back, of using #12 jack chain attached to
the end of the cable works well in a "typical" situation with no
insulation. Standard 4-pair CAT5e cable fits through the links on the
chain, so you don't need anything else to attach the cable to the
chain. If there is insulation, I use a 8-10' section of 3/4" tape
measure. Get it between the drywall and the insulation and push it
down... it will continue to hug the wall. Use the markings on the
tape to know when you've gone far enough. You may need to hunt for
the tape at the bottom a bit, but it works well.
Posted by DaveC on November 7, 2004, 2:16 am
All good suggestions.
But I still need to know if fire blocking will be an issue in most offices. I
know in homes, blocking between studs is common. If it is also in an office,
it'd be a real pain to get a cable around it, I'd think.
What's your experience?
DaveC
me@privacy.net
Similar ThreadsPosted
Fishing one network cable in wall? November 4, 2004, 6:01 pm
Wall mount network jacks October 6, 2005, 10:55 am
Creating a new network with cabling and wall outlets in 2 buildings June 14, 2005, 9:17 am
Need advice for a wall-mounted patch panel for home network January 17, 2006, 10:34 am
Fishing tips for finished basement without drop ceiling March 7, 2005, 2:27 pm
Wiring on RJ45 wall socket July 8, 2007, 6:22 am
Cat5 phone wall plates with post July 1, 2005, 11:40 am
Cat6 Patch Panel in Wall Enclosure August 9, 2005, 8:34 pm
Newbie question re connecting wall sockets November 10, 2006, 12:24 pm
Allen Tel hinged wall mount bracket screws September 30, 2004, 2:48 am
Blilnking network cable id-ers October 14, 2004, 11:20 pm
Leasing network cable infrastructure January 20, 2006, 2:45 pm
How to wire cable between network sockets January 23, 2006, 6:47 am
Phone + Network on 1 CAT5 cable? January 18, 2007, 10:12 am
Network in new house June 12, 2005, 6:48 pm
