LAN and Telecom Cabling Firewire using on existing Ethernet cable
Subject Author Date
Firewire using on existing Ethernet cable Ronald 08-06-05
Posted by Ronald on August 6, 2005, 7:36 am
Hi there,
I want to buy an DVD recorder with FireWire support. The DVD recorder
must connect to the internet for download TV guide information. On the
other hand i want connect with the computer to transfer files to and
from the DVD recorder. This is apperently not possible with the
existing ethernet cable. The DVD recorder suppert FireWire so i must
use another cable. Is it possible to use the existing ethernet cable to
connect to the DVD recorder with FireWire. Other solutions are also
nice
Ronald
Posted by Al Dykes on August 6, 2005, 11:53 am
>Hi there,
>nice
>Ronald
A FireWire PCI card for your PC shouldn't cost much. I think
that's what you want.
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Posted by Carl Navarro on August 6, 2005, 5:23 pm
>Hi there,
>nice
A quick search on Google for "firewire to ethernet converter" brings
up all kinds of hits. Try http://www.usbfirewire.com/ for starters.
Carl Navarro
Posted by Ronald on August 7, 2005, 10:51 am
Yes that information i find on the internet. But what i hear from
others that it is not so simply to transfer files between the dvd
recorder and the pc. Thus is it possible to transfer files over an
firewire cable.
Ronald
Posted by Carl Navarro on August 7, 2005, 6:32 pm
>firewire cable.
So what you really are asking is if you can control the DVD player
from your computer. Never mind the interface, find a DVD player that
can do that under any means and get the computer hardware that will
work.
A whole lot different than the question you asked....
carl
Similar ThreadsPosted
Firewire using on existing Ethernet cable August 6, 2005, 7:36 am
30 meter IEEE 1394 Firewire cable September 5, 2006, 3:47 pm
Homemade cat5 cable using existing phone line fails. March 11, 2006, 5:41 am
Ethernet cable shield November 23, 2004, 5:02 pm
Ethernet Cable Woes - On and Off every second February 19, 2007, 8:20 pm
Existing conduit w/fiber,copper,pull string February 21, 2005, 10:56 pm
Cable over ethernet for two Wireless access points July 23, 2004, 6:57 pm
CAT-5 cable stuck in ethernet port - can't remove April 26, 2006, 5:49 am
Re: Ethernet connection sensitive to cable length May 3, 2008, 12:37 pm
DIY Ethernet September 10, 2004, 8:57 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:56 pm
PoE and Ethernet switches October 1, 2005, 10:22 am
Re: ethernet polarity November 4, 2005, 10:44 pm
