LAN and Telecom Cabling Fiber to the home - What are the standards ?
Subject Author Date
Fiber to the home - What are the standards ? Al Dykes 02-25-05
Posted by David Lesher on March 6, 2005, 8:10 am
>Also, remember that even if you plug that FiOS wall wart into your own
>UPS, it won't do a bit of good if the fiber concentrator down the block
>has also lost power and its battery has run down.
From what I saw, the outside plant is all passive; there's nothing
to run down.
A host is a host from coast to coast.................wb8foz@nrk.com
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Posted by Watson A.Name - \"Watt Sun, th on March 12, 2005, 10:58 am
> "Watson A.Name - "Watt Sun, the Dark Remover""
own
block
> to run down.
Excellent. Then perhaps it will eliminate this problem.
http://sffma.net/tech_info_powering.htm
Of course, you still have the problem that if one fiber strand is broken
(commonly known as backhoe fade), the whole neighborhood loses dial
tone.
Posted by Watson A.Name - \"Watt Sun, th on March 5, 2005, 7:52 am
> I'm in suburban Verizon country and there are Verizon trucks all over
> the area these days. I asked one of the guys what's going on and they
> said they are pulling fiber. After we parted I began to think about
> it. I've heard of people in the area getting a multi-MB/sec
> residential fiber connection for about $50/month, real soon now. Does
> that sound right ?
> Are they really going to pull fiber to every house ? Do they do it
> all at once or just on new construction and/or when an exist
> house buys the new service ?
> What does the dmarc look like and what do they do with my POTS phone ?
> I'd guess they put in a black box with RJ11 for POTS and RJ45 for
> ethernet (served as PPPoE). Do they need 120VAC power ?
> Any other insights are appreciated.
Since when is it De Rigeur for Americans to imitate the French and put a
space before every question mark ?
Or are you just a hopeless Space Case ?
What is this nasty infection that's spreading around the net ?
That is certainly _not_ the way we learned to do it in school !
> a d y k e s @ p a n i x . c o m
> Don't blame me. I voted for Gore.
Similar ThreadsPosted
Fiber to the home - What are the standards ? February 25, 2005, 8:26 pm
Standards for pair colours? November 9, 2005, 6:39 pm
Home Wiring for DSL and 4 Extensions April 24, 2005, 1:13 am
New Home Wiring Questions February 1, 2006, 10:59 am
Fibers inside a home March 16, 2006, 7:52 am
Home Networking Advice May 9, 2007, 2:46 am
CAT6 HOME WIRING June 25, 2007, 1:31 pm
Supply Rack Mount Fiber Enclosures,Rack Mount Fiber Patch Panels,Rack Mount Terminal Panels April 9, 2006, 11:44 am
Fiber Distribution Frames,Fiber Optic Distribution Frames January 12, 2007, 11:10 am
Wiring home for satellite & ethernet June 23, 2005, 11:25 pm
retrofit home with structured wiring.. June 24, 2005, 6:22 pm
Home phone cabling -- Leviton alternatives October 24, 2004, 6:23 pm
mission critical home made cables August 23, 2007, 12:12 pm
Home Network Run Issue - Unsure next step June 15, 2007, 6:28 pm
802.11G health issue and home network cabling question September 25, 2006, 8:32 pm
