Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Robert Redelmeier on April 21, 2005, 5:32 am
Please log in for more thread options Possibly. That fiber pair is almost certainly good for 10 Mbit/s (most likely more), and 50 voice lines need 3.2 kbit/s, but that's uncompressed and 100%usage. > If so. What do I need on each end of the run?
> copper -> > fiber / fiber -> copper device?
> I'll appreciate any input as I'm new at this.
> Regards,
> - Frank
Posted by James Knott on April 21, 2005, 9:42 am
Please log in for more thread options Robert Redelmeier wrote: > and 50 voice lines need 3.2 kbit/s,
> but that's uncompressed and 100%usage. ???? A standard voice channel is 64 Kb/s Perhaps you meant 3.2 Mb/s? | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Justin Time on April 21, 2005, 8:52 am
Hey guys, a couple of things here. Voice channels are only 56 or 64K when they are digitized. But for the issue about replacing the 50-pair tie cable. You would need four strands of fiber and four channel banks having the appropriate interfaces. All-in-all it would be cheaper and easier to replace the 50-pair with a new one that is at least Cat3. Rodgers Platt | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Robert Redelmeier on April 21, 2005, 3:46 pm
>> but that's uncompressed and 100%usage. > A standard voice channel is 64 Kb/s Perhaps you meant 3.2 Mb/s?
Correct. That post "escaped" early. Note there was no --sig. I also intended to add that fiber->copper is normally Ma's
stuff. RTs are full of this sorts of gear. OP should talk
to his PBX vendor to see if they have fiber units (likely). -- Robert >
Posted by Watson A.Name - \"Watt Sun, th on April 22, 2005, 4:22 am
> Correct. That post "escaped" early. Note there was no --sig. > > I also intended to add that fiber->copper is normally Ma's > stuff. RTs are full of this sorts of gear. OP should talk > to his PBX vendor to see if they have fiber units (likely). Used to be. Nowadays it seems everything has gone from circuit switched to packet switched. But I don't know if that means that inexpensive used circuit switched gear is available. It may be more economical to replace the cable. > -- Robert
| Similar Threads | Posted |
| Fiber to 50-pair conversion | April 20, 2005, 5:24 pm |
| Supply Rack Mount Fiber Enclosures,Rack Mount Fiber Patch Panels,Rack Mount Terminal Panels | April 9, 2006, 11:44 am |
| Fiber Distribution Frames,Fiber Optic Distribution Frames | January 12, 2007, 11:10 am |
| Fiber for less | February 7, 2008, 12:22 pm |
| 10-Gig fiber color | August 16, 2004, 6:23 pm |
| Fiber question | November 16, 2004, 6:24 pm |
| fiber help needed please. | September 8, 2004, 1:47 pm |
| Fiber termination | October 15, 2004, 10:20 pm |
| Which Fiber Switch | February 23, 2005, 10:45 am |
| Fiber looping | January 14, 2006, 2:39 am |
| multimode fiber + GBIC | January 14, 2005, 11:43 pm |
| No polish Fiber terminations? | January 27, 2005, 1:28 am |
| Fiber to the home - What are the standards ? | February 25, 2005, 8:26 pm |
| fiber termination - practical help please | July 28, 2005, 4:41 am |
| Trouble with B2B fiber connection | August 3, 2005, 9:03 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> 50-pair burried cable (for voice) and was wondering if I
> can use an existing Fiber run.
