LAN and Telecom Cabling Fiber optic cable question
Subject Author Date
Fiber optic cable question zeussix 09-20-06
Posted by zeussix on September 20, 2006, 5:48 pm
I have been asked to run a fiber optic cable of about 600ft through a
warehouse. There are conduit pipes overhead about 30ft high that run
the length. is it possibe to lash the fiber cable to those conduits?
and if so what type of cable would i use?
Posted by Robert Redelmeier on September 21, 2006, 10:36 am
> through a warehouse. There are conduit pipes overhead about 30ft
> high that run the length. is it possibe to lash the fiber cable
> to those conduits? and if so what type of cable would i use?
Well, the preferred technique is to build a cable-tray and
put the fiber in it. This will win the heart of even the most
black-hearted electrical inspector. So long as you bond it :)
But people run fiber along conduit all the time, and it's
tough for anyone to argue so long as it isn't conductive.
It's safer than pull-string.
I'd use regular indoor grade. All that I've seen have enough
kevlar for strength since they're often used for riser runs in tall
buildings. If you have doubts about your connectorizing ability,
take the trouble to measure well and get a length custom mfg'd.
Allow for plenty of slack.
That conduit is going to have supports at least every 25ft
also to support the fiber (two-point tie--you don't want the
cable shuffling slack lengthwise). If you're worried about the
"clothesline effect" and the hanging arc being caught by moving
vehicles/equipment, you can add mid-point ties. One trick I've
seen used is to lift and wrap the arc two times around the midspan
and tie-down. The wraps add 4 support points to the length.
-- Robert
Posted by Dmitri(Cabling-Design.com on September 21, 2006, 3:28 pm
We have an entry about this in our cabling FAQ:
http://www.cabling-design.com/interaction/tips/21Feb20001.shtml
Bottom line: the code says you can't strap a communications cable (I
interpret is as copper or fiber) to the exterior of ANY conduit. Have I
seen it done? Of course! However, much better approach would be to use the
threaded rods that most likely support the conduit to install your very
own J-hook line. Use brackets with clamps that let you install a hook onto
existing installed rod. There will most likely be a slight problem: the
hooks may be a little too far apart which may be causing too much sag. It
actually depends on the size and stiffness of the cable you use. The
famous "a hook every 5 feet" rule only applies to UTP copper cables and
you can go further than that with fiber. However, too much sag will make
the cables too insecure and will make them swing in drafts (which
accelerates microbends aging of fiber) and simply they can be accidentally
pulled at when someone else needs to go into the ceiling later for
whatever reason. To prevent the unwanted sag (you want at least some sag
'cause you don't want much tension) you can clamp a steel messenger wire
to the same rods, tighten the messenger wire and then lash the fiber cable
to the messenger.
Whole another approach would be to go even higher and clamp your J-hooks
directly onto the beams thus elimination messing with existing conduits
altogether. I guess, this kind of install is exactly what you are trying
to avoid, but in some instances it is not possible to avoid.
Oh, and another thing: you can use regular (non-plenum) grade fiber optic
cable. However, to add some stiffness to the cable you can opt for
non-plenum rated indoor/outdoor version. Some designs use the same type of
buffered fiber inside as the indoor cables but much thicker jacket made of
different plastics (plus stiffener rods in the center) that can eliminate
the unwanted sag.
Good luck!
Best Regards,
Dmitri Abaimov, RCDD
Home Cabling Guide, Cabling Forum, color codes, pinouts and other useful
resources for premises cabling users and pros
http://forums.cabling-design.com/ |
| *** a better way
to USENET *** |
| no-spam Web and RSS interface to your favorite
newsgroup |
| comp.dcom.cabling - 2925 messages and counting! |
Similar ThreadsPosted
Fiber optic cable question September 20, 2006, 5:48 pm
Grounding rack for sheathed fiber optic cable August 11, 2005, 3:31 pm
Fiber optic safety gloves September 6, 2005, 9:24 am
Fiber Optic & Copper services December 19, 2005, 1:21 pm
NorCal Fiber Optic Contractor. Splicing-Testing-Termination November 24, 2006, 1:39 pm
Fiber Distribution Frames,Fiber Optic Distribution Frames January 12, 2007, 11:10 am
Fiber question November 16, 2004, 6:24 pm
Splicing Fiber Question February 19, 2007, 12:47 am
Fibre Optic work June 14, 2005, 10:51 pm
Fibre Optic Couplers July 6, 2005, 9:29 pm
Affixing Fiber Cable to a Support September 19, 2007, 3:02 pm
Supply Mini-Com Coupler Modules ,Mini-com Coupler Modules,Panduit Mini-com Coupler Module,Panduit Minicom Modules,Panduit Mini-Com Module,Panduit Mini-com Fiber Optic Adapter Modules April 23, 2006, 9:45 am
fibre optic explanation needed October 11, 2004, 1:25 pm
Fibre optic crimp / terminate tool kit.. June 9, 2005, 10:17 pm
Question about Cat 7 cable February 1, 2005, 2:03 pm
