LAN and Telecom Cabling Faster net over 600'...?
Subject Author Date
Faster net over 600'...? Kenneth 02-13-05
Posted by Robert Redelmeier on February 14, 2005, 1:45 am
> It is for imaging that this is all of interest to me...
Ah, so you probably really do need the bandwidth.
> The main run is close to straight, but inside the buildings
> that is definitely not the case.
If the run is straight conduit, it is much easier to pull
in a fiber line. Corners make long pulls tough.
-- Robert
Posted by Kenneth on February 13, 2005, 10:03 pm
On Sun, 13 Feb 2005 22:45:58 GMT, Robert Redelmeier
>-- Robert
OP here...
Is pulling fiber materially different from pulling other
forms of cable such as the 10-Base-2 we now have?
Thanks,
Kenneth
If you email... Please remove the "SPAMLESS."
Posted by James Knott on February 14, 2005, 12:41 am
It's easier to break.
Also, if you check, you'll find it is spelled "fibre", not "fiber".
Posted by Kenneth on February 14, 2005, 9:34 am
On Sun, 13 Feb 2005 21:41:03 -0500, James Knott
Howdy,
Regarding the breakage issue, I think we would be fine. The
underground conduit was properly designed for the purpose
and has only smooth curves.
Regarding the spelling:
I am US based, and on this side of the pond it is
"fiber." 'Sorry for any confusion.
All the best,
Kenneth
Posted by Watson A.Name - \"Watt Sun, th on February 15, 2005, 3:47 am
Only if you're not in the U.S. ;-)
Seems that the Nat'l Institute of Standards and Technology, a part of
the U.S. Gov't, uses the term fiber extensively.
http://externalsearch.nist.gov/search?q=fiber&btnG=Google+Search&site=de
fault_collection&output=xml_no_dtd&client=default_frontend&sort=date%3AD
%3AL%3Ad1&proxystylesheet=default_frontend&oe=UTF-8
Similar ThreadsPosted
Faster net over 600'...? February 13, 2005, 4:07 pm
