LAN and Telecom Cabling Faster net over 600'...?
Subject Author Date
Faster net over 600'...? Kenneth 02-13-05
Posted by T. Sean Weintz on February 15, 2005, 8:47 pm
James Knott wrote:
> Fibre can be much faster than copper, though somewhat more expensive to
> install.
Funny, I have a multimode patch cable, and a piece of cat5e, both
sitting on my desk. Neither one seems to want to move at all, let alone
one faster than the other.
Posted by Phil Partridge on February 16, 2005, 12:28 pm
>> install.
That's because there is only about 20% difference in the 'speed' between
the two mediums. - Unless you wan the same electron out, as you put in.
Phil Partridge
philp@pebbleGRIT.demon.co.uk
Remove the grit to reply
Posted by Robert Redelmeier on February 13, 2005, 11:56 pm
> If I were to go the fibre (or fiber <g>) route could I get
> significantly increased speeds? And, if so, would the costs
> be insane?
Yes, you could go from 10 Mbit/s to 100 Mbit/s fairly
easily (especially if that coax is in a straight conduit).
Installation is the big variable.
Whether it helps or not is a totally different question,
and depends greatly on the nature of the traffic between
the systems. For many apps, 10 is more than enough. But
big pushers like backup or imaging can benefit from more.
-- Robert
Posted by Kenneth on February 13, 2005, 7:32 pm
On Sun, 13 Feb 2005 20:56:14 GMT, Robert Redelmeier
>> be insane?
>-- Robert
Hi Robert,
It is for imaging that this is all of interest to me...
The main run is close to straight, but inside the buildings
that is definitely not the case.
Why would the run being straight matter?
Thanks,
Kenneth
If you email... Please remove the "SPAMLESS."
Posted by James Knott on February 13, 2005, 7:53 pm
The photons have to slow down for the curves. ;-)
Similar ThreadsPosted
Faster net over 600'...? February 13, 2005, 4:07 pm
