LAN and Telecom Cabling Faster net over 600'...?
Subject Author Date
Faster net over 600'...? Kenneth 02-13-05
Posted by Kenneth on February 13, 2005, 4:07 pm
Howdy,
I have two systems that are about 600 feet apart.
They are currently connected by (and forgive me if I don't
have the proper name) 10-Base-2 with BNC fittings running
underground between two buildings.
This cable was chosen over Cat 5 because of the distance.
As currently configured, the net between these two systems
runs at 10 Mbps and that generates a few questions:
Are there faster alternatives in our situation? Are there
faster alternatives that could run over the same cable?
Specifically, might our current speed limitation be caused
by the cards we use? Might there be cards available that use
BNC fittings on such cable but run at higher speeds?
We would be interested in increasing speed at reasonable
costs and could certainly run another cable if that were the
way to go. I will add that I have used our current setup for
about four years and except for the speed, it has functioned
reasonably well.
Sincere thanks for any suggestions about this,
Kenneth
If you email... Please remove the "SPAMLESS."
Posted by James Knott on February 13, 2005, 4:11 pm
Kenneth wrote:
> Howdy,
> reasonably well.
There are no standard, inexpensive methods to run more than 10 Mb over coax
cable. If there's power available midway, you could run a switch to
regenerate the signal. Failing that, your best bet would be fibre.
Posted by Kenneth on February 13, 2005, 4:17 pm
On Sun, 13 Feb 2005 13:11:20 -0500, James Knott
>Kenneth wrote:
>> Howdy,
>> reasonably well.
Hello again,
Thanks for the speedy response.
I should have said that we have no access between the two
systems.
If I were to go the fibre (or fiber <g>) route could I get
significantly increased speeds? And, if so, would the costs
be insane?
Thanks for any further information,
Kenneth
Posted by Al Dykes on February 13, 2005, 4:31 pm
>>Kenneth wrote:
>>> Howdy,
>>> reasonably well.
>Hello again,
>systems.
>be insane?
>Kenneth
Can some knowledgable person post the product description for the
lowest-tech fiber that's appropriate for something like this, and an
appx cost per foot.
Also the URL for the economy model transeivers appropriate to convert
the fiber to RJ45 appropriate to be patched into a hub/switch.
What are the cost/distance/speed tradeoffs for 10Mb and faster, up to
100Mb/sec. ?
This gets discussed lots but I don't recall it ever being reduced to
numbers. It should be Q#1 for a FAQ document.
Thanks
a d y k e s @ p a n i x . c o m
Don't blame me. I voted for Gore.
Posted by Al Dykes on February 13, 2005, 4:35 pm
>>>Kenneth wrote:
>>>> Howdy,
>>>> reasonably well.
>>Hello again,
>>systems.
>>be insane?
>>Kenneth
>appx cost per foot.
>100Mb/sec. ?
>Thanks
Also what kind of one-off field termination is appropriate for this
kind of DIY fiber project ?
Similar ThreadsPosted
Faster net over 600'...? February 13, 2005, 4:07 pm
