Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Lucas Tam on April 12, 2005, 7:49 pm
Please log in for more thread options > Lucas Tam wrote:
>> Of course option #1 is preferred, but if that is not possible, try
>> #2. If # 2 fails, try boosting the signal with a zero loss booster. >> It's basically an amp which maintains a 0db signal throughout the >> run. Electroline has one such model - you can find them on eBay. >> >> Also you should consider using an amplifer anyways - since a splitter >> often degrades the signal considerably. >> >
> Do you mean an Active (zero loss) Splitter, Yup, that's what I'm talking about. -- Lucas Tam (REMOVEnntp@rogers.com) Please delete "REMOVE" from the e-mail address when replying. http://members.ebay.com/aboutme/coolspot18/ | ||||||||||||||||||||||
| Similar Threads | Posted |
| Extending coax cause signal loss? | April 8, 2005, 11:02 pm |
| Extending cat5e - Help! | August 6, 2005, 4:20 pm |
| 10BaseT over RG6 Coax | July 31, 2008, 11:19 am |
| Can I use somehow use CAT5 instead of COAX for SPDIF? | October 11, 2004, 8:24 pm |
| Coax Grounding Requirements | January 29, 2006, 9:58 pm |
| How to crimp RCA connectors onto RG59 coax | July 11, 2006, 4:12 pm |
| Convert old Coax RG59/6 to Cat 5 while wiring house -- possible? | September 4, 2004, 2:16 pm |
| EMI Sensitivity of Coax and Twisted Pair wires | June 26, 2006, 6:16 am |
| Can I use a CAT5 cable as a TV Coax cable? | October 14, 2006, 2:13 pm |
| splitting composite video signal | July 2, 2006, 7:01 am |
| Power + DSL signal in same 700ft cable length | October 12, 2006, 6:35 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
