LAN and Telecom Cabling Extending coax cause signal loss?
Subject Author Date
Extending coax cause signal loss? Newsgroups \(std news via SBC\ 04-08-05
Posted by Dale Farmer on April 9, 2005, 5:05 am
"Newsgroups (std news via SBC)" wrote:
> Thanks Crackhead! (oh, and you too James ;)
> Now assuming i can't stretch the cable far enough...
> Can anyone tell me the best method when using an existing
> cable to pull new cable?
> One cable is in an exterior wall and the roof is so low it will be
> difficult to even get close.
> Overapping the two cables and taping them together should work
> as long as the existing hole(s) are big enough. But what it they
> are not? Tape them end-to-end??
To use the old cable, to pull a new cable. Best to go with a
two step process. Tape some pulling twine to the old cable,
and us the old cable to pull in the pulling twine. Now you can
attach the twine to the new cable and pull that in. It is usually
wise to pull in a second piece of twine when you pull in the
first one, that way if you break it pulling in the second cable,
you are not completely screwed.
--Dale
Posted by Watson A.Name - \"Watt Sun, th on April 9, 2005, 1:56 pm
No doubt it will break if you use cheap twine. Use some decent rope to
pull the cables with.
> --Dale
Posted by Dale Farmer on April 10, 2005, 6:08 am
> > --Dale
I use cheap electricians pulling twine. I buy it by the 5000 foot bucket
at
the electrical supply house. It's cheap stuff, but it has more strength
than
my arms do. For pulling in heavy cable, ( which this coax sure isn't ) I
have some braided nylon tape, which has a breaking strength of somewhere
around a thousand pounds. The second strand is in case you abrade it
on a sharp edge inside the wall you can't see, which will severely weaken
any sort of pulling twine or rope.
--Dale
Posted by Lucas Tam on April 11, 2005, 4:42 am
$RQ7.491@newssvr14.news.prodigy.com:
> * use the existing cable to pull new cable. Or,
> * extend the cables using "Feed Thru/In Line Connectors"
> Obviously the latter would be easier, but I want the job
> done right and will pull new cable it that's the "preferred"
> method. Any input would be appreciated.
Of course option #1 is preferred, but if that is not possible, try #2. If #
2 fails, try boosting the signal with a zero loss booster. It's basically
an amp which maintains a 0db signal throughout the run. Electroline has one
such model - you can find them on eBay.
Also you should consider using an amplifer anyways - since a splitter often
degrades the signal considerably.
Lucas Tam (REMOVEnntp@rogers.com)
Please delete "REMOVE" from the e-mail address when replying.
http://members.ebay.com/aboutme/coolspot18/
Posted by Ed Nielsen on April 11, 2005, 11:27 am
Do you mean an Active (zero loss) Splitter, which has an amplifier with
gain equal to the insertion loss of the splitter. The only way for an
amplifier to compensate solely for the loss of passives (splitters,
directional couplers) is to attenuate the output of the amp equal to the
loss through the devices. (You could pad the input instead, depending
on the input levels to the amp.) Manufacturers have no idea what any
given distribution system is like.
CIAO!
Ed N.
Similar ThreadsPosted
Extending coax cause signal loss? April 8, 2005, 11:02 pm
Extending cat5e - Help! August 6, 2005, 4:20 pm
10BaseT over RG6 Coax July 31, 2008, 11:19 am
Can I use somehow use CAT5 instead of COAX for SPDIF? October 11, 2004, 8:24 pm
Coax Grounding Requirements January 29, 2006, 9:58 pm
How to crimp RCA connectors onto RG59 coax July 11, 2006, 4:12 pm
Convert old Coax RG59/6 to Cat 5 while wiring house -- possible? September 4, 2004, 2:16 pm
EMI Sensitivity of Coax and Twisted Pair wires June 26, 2006, 6:16 am
Can I use a CAT5 cable as a TV Coax cable? October 14, 2006, 2:13 pm
splitting composite video signal July 2, 2006, 7:01 am
Power + DSL signal in same 700ft cable length October 12, 2006, 6:35 pm
