LAN and Telecom Cabling Evaluating STP Quality for Gigabit Ethernet
Subject Author Date
Evaluating STP Quality for Gigabit Ethernet Will 07-22-06
Posted by Will on July 25, 2006, 2:35 am
> > You would think, yet we have gigE NetGear GS116 switches in
> > individual rooms uplinked to GSM7224 layer 2 switches in the
> > central room, and I have yet to see a single error reported
> > on any switch. I'm not believing the report somehow.
> Why do you believe that links are being run at 100, let
> alone gig? Some very smart equipment falls back to 10.
> Almost all will fall back to 100.
Because the link lights on the switch, as well as the software application,
both say gigabit speed for all attached links.
Will
Posted by Robert Redelmeier on July 25, 2006, 2:02 pm
> software application, both say gigabit speed for all
> attached links.
And do you actually see 13+ MByte/s transfer speeds?
The lights are often wrong and the software may be
if it's just talking to the etherchip.
-- Robert
Posted by Will on July 25, 2006, 5:21 pm
Yes, we seem to be getting about 12 to 20 MB/sec.
I'm a little perplexed why we see the bandwidth peek around 20 MB/sec then
go to zero for a while before jumping again to a peak.
Will
Posted by DLR on July 25, 2006, 6:24 pm
We have a printer which does not correctly negotiate when connected to a
gig link. We're waiting on a fix from the manufacturer. But until I
looked at the error rates, it seemed to be a protocol problem. It would
work fine if we sent jobs via AppleTalk. Say 1 minute before printing
started. But if we used IP as the transport the same job would take 1 to
3 hours before it would print. When I checked the switch stats, CRC
errors outnumbered good packets when doing IP. But until I looked at it
everyone was saying our computers couldn't talk IP correctly as it did
work with AppleTalk. Turned out the issue was the interface on the
printer was much more likely to mishandle large packets when connected
to a gig link.
My point is once you have a link with issues, problems can manifest
themselves in strange ways.
Posted by Robert Redelmeier on July 25, 2006, 7:59 pm
Definitely gig.
> MB/sec then go to zero for a while before jumping again to a peak.
There are a number of possible explanations: If it's quick
cycling (ms) it might just be track seek. If it's much slower
(s) and erratic, then that may be all the traffic to be sent!
-- Robert
Similar ThreadsPosted
Evaluating STP Quality for Gigabit Ethernet July 22, 2006, 9:15 pm
Cat 5e vs 6 and gigabit ethernet February 4, 2006, 1:12 am
Gigabit Ethernet Cabling November 17, 2004, 3:55 pm
Shielded Cat5e for Gigabit Ethernet September 14, 2004, 9:35 pm
Patch Cable Quality - Brand Differences? August 21, 2006, 10:28 am
Ok this may be a beaten up subject but...c5e vs c6 gigabit. June 1, 2006, 10:11 am
Gigabit Cabling and Auto-MDIX Problems May 24, 2005, 1:41 am
DIY Ethernet September 10, 2004, 8:57 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:56 pm
PoE and Ethernet switches October 1, 2005, 10:22 am
Re: ethernet polarity November 4, 2005, 10:44 pm
Re: ethernet and AC in same conduit January 2, 2009, 8:47 pm
Ethernet cable shield November 23, 2004, 5:02 pm
