LAN and Telecom Cabling Evaluating STP Quality for Gigabit Ethernet
Subject Author Date
Evaluating STP Quality for Gigabit Ethernet Will 07-22-06
Posted by Will on July 22, 2006, 9:15 pm
We are converting over our network slowly to gigabit ethernet, and I wanted
to better understand how I can evaluate the quality of the existing copper
wiring. We are in a building where the twisted pair wiring was done maybe
15 years ago, and the quality is not very high. I doubt that the patch
panels are rated for gigabit ethernet, nor is the twisted pair wiring in the
building probably. On the other hand, our runs are extremely short, with
maybe 5000 sq feet of office and lab space surrounding a computer room where
the wiring terminates.
What distance can gigabit ethernet run reliably over non-qualified CAT5
cabling?
What is the cheapest tester that would give us some way to characterize the
quality of patch cables as well as wiring at each wall jack in the building
through to its patch panel in the computer room?
Will
Posted by DLR on July 23, 2006, 2:38 am
> cabling?
First off are you sure it even has all 4 pairs connected?
It's hard to imagine you'd get enough positive results to make it worth
testing any of it. I'd just take the testing budget and put it into the
upgrade plan.
If you are moving to gigabit then I'm sure you're also moving to managed
switched. Right? So to make sure you have a mess, hook up your new
managed switch to a few runs and walk around the office with a gig
laptop and try to watch some streaming video with it. While doing this
see what the connection rate is for the laptop and see what the switch
is getting for error rates.
Posted by Robert Redelmeier on July 24, 2006, 2:09 pm
> and I wanted to better understand how I can evaluate the
> quality of the existing copper wiring. We are in a building
> where the twisted pair wiring was done maybe 15 years ago,
In 1991 you'd be luckly to get wired with Cat3. That isn't
spoec'd for 100 MHz. are you running 100baseTX successfully?
Min errors, congestion or retransmits? If it won't run 100FD,
there isn't a prayers of it running gig.
> On the other hand, our runs are extremely short, with maybe
> room where the wiring terminates.
Short helps. But some of your runs are probably 100ft,
about 1/3 the max.
> to characterize the quality of patch cables as well as
> wiring at each wall jack in the building through to its
Try running `ttcp` software on two machines and see
if you get wirespped. Also try full duplex.
-- Robert
Posted by Will on July 24, 2006, 4:19 pm
You would think, yet we have gigE NetGear GS116 switches in individual rooms
uplinked to GSM7224 layer 2 switches in the central room, and I have yet to
see a single error reported on any switch. I'm not believing the report
somehow.
Where can I get a ttcp that would run on Windows command line?
Will
Posted by Robert Redelmeier on July 24, 2006, 6:21 pm
> individual rooms uplinked to GSM7224 layer 2 switches in the
> central room, and I have yet to see a single error reported
> on any switch. I'm not believing the report somehow.
Why do you believe that links are being run at 100, let
alone gig? Some very smart equipment falls back to 10.
Almost all will fall back to 100.
> line?
Search for ttcp or ttcp.exe ?
-- Robert
Similar ThreadsPosted
Evaluating STP Quality for Gigabit Ethernet July 22, 2006, 9:15 pm
Cat 5e vs 6 and gigabit ethernet February 4, 2006, 1:12 am
Gigabit Ethernet Cabling November 17, 2004, 3:55 pm
Shielded Cat5e for Gigabit Ethernet September 14, 2004, 9:35 pm
Patch Cable Quality - Brand Differences? August 21, 2006, 10:28 am
Ok this may be a beaten up subject but...c5e vs c6 gigabit. June 1, 2006, 10:11 am
Gigabit Cabling and Auto-MDIX Problems May 24, 2005, 1:41 am
DIY Ethernet September 10, 2004, 8:57 pm
Ethernet cabling used outside July 29, 2004, 7:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:56 pm
PoE and Ethernet switches October 1, 2005, 10:22 am
Re: ethernet polarity November 4, 2005, 10:44 pm
Ethernet cable shield November 23, 2004, 5:02 pm
Ethernet STP Patch in STP installation July 25, 2006, 9:38 am
