LAN and Telecom Cabling Ethernet cabling used outside
Subject Author Date
Ethernet cabling used outside Bob Alston 07-29-04
Posted by Michael Quinlan on August 2, 2004, 7:00 am
Dmitri(Cabling-Design.com) wrote:
> Well, not sure about the back of the track ;-), but Home Depot sells
> 1000ft boxes of of General Cable's plenum CAT5E for $189, indoor PVC CAT5E
> for $66 and outdoor CAT5E for $45. The difference could be more extreme:
> 0.300 coax cable costs me $3.32/ft plenum and only $0.31 outdoor
Take another look, and I think you'll see that the outdoor-rated cable
is only 500', not 1000' - making the cost per foot higher than for the
riser-rated cable.
Posted by Dmitri(Cabling-Design.com on August 3, 2004, 5:43 am
Hi Michael,
I certainly did not mean to sound like a Home Depot salesman that knows
his inventory as the back of his hand. You may very well be right because
the OSP cable should have slightly larger outside diameter. I may just
stop by HD to check it out one more time. But the point is: even at some
premium in price using an OSP cable outdoors does justify the save
headache to me.
BTW, the coax prices I used are from a valid, recent source, not Home
Depot.
Dmitri Abaimov, RCDD
http://www.cabling-design.com
Cabling Forum, color codes, pinouts and other useful resources for
premises cabling users and pros
http://www.cabling-design.com/homecabling
Residential Cabling Guide
>> sells
>> PVC CAT5E
>> extreme:
> riser-rated cable.
Article posted with Cabling-Design.com Newsgroup Archive
http://www.cabling-design.com/forums
no-spam read and post WWW interface to your favorite newsgroup -
comp.dcom.cabling
Posted by Michael Quinlan on August 3, 2004, 6:22 am
> Hi Michael,
> headache to me.
> Depot.
Whenever running cable outdoors, I use outdoor rated cable. Of course,
I charge the customer accordingly.
Posted by Dmitri(Cabling-Design.com on August 4, 2004, 9:46 pm
Just to follow up on this after a visit to HD:
HD prices are $39 for 500' PVC and $57 for 500' indoor/outdoor CAT5E
Indoor/outdoor cable is a different animal from outdoor only, so I guess,
the slight price premium is justifiable in this case: no need to
transition to indoor cable for indoor pulls over 50'.
>> sells
>> PVC CAT5E
>> extreme:
> riser-rated cable.
comp.dcom.cabling
Posted by Mikkel on August 3, 2004, 6:45 pm
"Bob Alston" <bobalston AT aol DOT com> wrote in message
> What has been your experience in using standard Ethernet cable, cat5 or
cat6
> in an outside situation? I need to run some Ethernet cable outside, up
the
> outside wall to the top of the 2nd story, then under the 2nd story
overhang,
> adjacent to the gutters and then inside to the access point. Anyone see a
> need to find specific outdoor rated Ethernet cable or should garden
variety
> cat5/cat6 work?
I have had a normal PVC jacketed Cat 5e cable running from one building to
another for about 5 years now.
The cable is winded around a thin wire wich is going 5 m above the ground,
the run is around 25 m.
It has lasted for wind, rain, sun, snow and ice.
-Mikkel
Similar ThreadsPosted
Ethernet cabling used outside July 29, 2004, 7:57 pm
Gigabit Ethernet Cabling November 17, 2004, 3:55 pm
DIY Ethernet September 10, 2004, 8:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:57 pm
Cat 5 for phone and ethernet? December 20, 2004, 9:56 pm
PoE and Ethernet switches October 1, 2005, 10:22 am
Re: ethernet polarity November 4, 2005, 10:44 pm
Cat 5e vs 6 and gigabit ethernet February 4, 2006, 1:12 am
Re: ethernet and AC in same conduit January 2, 2009, 8:47 pm
Ethernet cable shield November 23, 2004, 5:02 pm
Ethernet STP Patch in STP installation July 25, 2006, 9:38 am
Ethernet Cable Woes - On and Off every second February 19, 2007, 8:20 pm
Ethernet: which RJ45 pins? August 9, 2007, 9:49 am
RJ45 splitter for Ethernet - possible ? March 28, 2008, 11:56 am
Re: Ethernet and AC in conduit for remote WAP January 3, 2009, 1:21 pm
